repair a worn cap jewel
justin457
7 hours ago, justin457 said:
i have a watch that has a dent in the sapphire jewel that the pivot wore a depression in and it doesn't look like i will find a replacement cap jewel any advice ?
You can grind it flat with diamond paste or powder and oil on a sheet of glass.
4 hours ago, justin457 said:
it is a harvey watch and where would i get the diamond powder and what grit to use
I am using these chinese pastes sold in 5g syringes. Under 1 USD per piece lol
Get the 0.5 and 2.5, the latter is the coarse, use this first and then polish with the other.
The jewel should be changed. After grinding the pivot fitting will be incorrect.
If you require diamond powder (mix with oil) I use Bergeon with 3 different grades & I purchased from Cousins.
I do agree that the cap jewel should be replaced, but if the jewel is set in an incabloc type of fitting, you could get away with lapping out the blemish and polishing the jewel.
I say this because the the jewel will be held down by the incabloc spring ensuring that the jewel is seated correctly in the setting.  This in turn will ensure that the original end end float is maintained.
Geo you could be correct, however the original post is not specific as to where it is worn to be 100% sure it is possible. Personally I think it is just not worth the risk & time required so I would just change it (if I could find a replacement that is)
5 hours ago, justin457 said:
the cap jewel is not a incabloc setting it is the old pocket watch cap jewels
Forget re-finishing the old jewel, you will need to find a replacement.  I can think of a way around the problem, but it would be a bodge so I won't even describe it.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
