I definitely recommend getting one Rossco, you'll find it a useful tool in your armoury for cleaning lots of things as well as watches.
Well, the last of my tools and accessories I've ordered have finally all arrived today so this is next on my list.
I've seen a number of eyeglass ultrasonic cleaners that seem to be the right size and the right price maybe to start off with so we'll see.
From my limited understanding, the chemicals that are put in them are also very important consideratons.
Thanks for the advice on this Geo.  Much appreciated!
Rossco, for cleaners I use L&R ultra fine cleaner and L&R #3 rinse and I have very good results. I'm planning to go Zenith when these bottles run out just to compare results. I like the watches to look factory new and so far L&R has done a rather good job but I want better. Careful with some solutions and heat (even the heat generated by the ultrasonic machine) since they are highly flammable.
Edited by bobm12
Thanks for the heads up on the L&R cleaner and rinse Robert, much appreciated.
I was going to try just an industrial cleaner that mixes with water to start but I guess I'm going to have to pick an ultrasonic machine first and then to see if it's compatible with some of the flammable solvents and solutions.
I'd hate to dissolve my new ultrasonic cleaner! :)
Rossco, here's a post that I made in this thread http://www.watchrepairtalk.com/topic/707-ultrasonic-vs-watch-cleaning-machine/
"All you need is one ultrasonic cleaner. Put water in the machine and have separate jars with your preferred solutions in them. All you have to do is place the jars into the water and the vibrations will penetrate the glass and clean the parts."
It might help you with your decision.
Geo, I saw that article about the glass containers and was very intrigued and interested in trying it but everywhere I've gone to so far, locally here at least, that advertised this "Magnasonic" model of inexpensive (cheap) ultrasonic cleaner I found, doesn't stock them and they are only available online.
I want to see it and check it out first before buying so I'm at a stalemate until I find one in person but I'm going to try that tip as soon as I get one.  Thanks for sharing.
Hi Rossco, this is the model of cleaner that I have. I've only had one small glitch when a connection gave a problem, probably caused by the ultrasonic vibrations. All I had to do was push it back on tightly.
http://www.ebay.co.uk/itm/0-4G-2L-50W-Professional-Digital-Stainless-Ultrasonic-Cleaner-Bath-with-Heater-/170934262268?pt=UK_Health_Beauty_Tattoos_BodyArt_SM&hash=item27cc79d9fc
There are quite a few like this with only subtle changes to the switches. I actually bought mine from China.
Thanks Geo, this one you show on e-bay looks similar to one of the 'alleged' Canadian manufacturers I've found that I bet they buy their electronics and transducers from China and put them in their own enclosures - there, Canadian made!
Oh well, I think I'm going to have to be careful in getting a good one but it seems they are all from China ultimately.
I appreciate you sharing your experiences.
I'm curious but did you have it long before it malfunctioned?
Three years of fairly frequent use cleaning all sorts of things. Although it had the hick up, it only took five minutes to fix and it's working perfectly.
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
