Good afternoon all
I am after a mainspring for an old pocket watch. The height is 3.38mm with a thickness of 0.25mm and a length of 53.5cm. The inside diameter of the barrel is 17.8mm. The end that hooks onto the inside of the barrel has a hole in it only. I can't find the spring on Cousins website and I don't have the GR code. I found this one 34025560195 which is near. I have asked if it has a hole in the barrel attatchment end but got told it has a normal end so am unsure what is considered normal.
If anyone could please help with this it would be most appreciated.
Many thanks
Andy
I can't answer your question as you posted it.
When I need a mainspring for a vintage P/W I go to EBAY or Daves watch parts and search for " Mainspring for (say) hamiltion 992 B " and you will find exactly what your looking for..
Hi
Thanks Tim. I can't search for the movement unfortunately as it was made in 1901 and it has no markings on it. I know the date and the case maker only but have no model number etc so am struggling. The enamel dial doesn't have any name on it either. I was asking that based on thmeasurements given of the original spring would the product code listed on the cousins website be a suitable replacement as it does not list what barely attachment end it has in the code as say a GREEN code would?
I do not have a GR code book but searching on the site showed no such code for the spring I require. Apologies for the way I asked the question in my original post as looking back it was not clear :-(
Andy
The spring you have found on Cousins is a bit long... but you are probably going to have to modify one anyway as they don't have any hole end springs near the size you need. I would go for 3402354017 (no idea why Cousins have stopped listing by GR number)
See this page for more info on calculating what the best match would be as you may not have that fitted today http://www.vintagewatchstraps.com/blogmainsprings.php#
The standard (non-automatic) spring has a hooked end, but you can cut this off and punch a hole... see here for more
Thank you so much for the reply Stuart it was most helpful. Would there be anything stopping me using a hooked end in a barrel that has a rivet in it to hold the spring as it would prevent the spring from rotating when being wound up and free length tension in the spring from being coiled up would hold it tight against the barrel inner wall? Just wondering out of interest more than anything. I still find it fascinating getting to learn how to order parts etc.
Again many thanks to everyone who has posted answers and provided me with guidance.
Andy
Was just wondering as I serviced a pocket watch recently that was like this as the hook in the barrel looked similar but it had a hooked spring fitted to it. I will modify the spring you suggested as it is easily done. I am a perfectionist sadly so it has to be done right.
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
