Removing stain on glass
Hi,
I have received a watch that has at some point gone into a swimming pool with the crown unscrewed. The movement has been cleaned up and it working fine but there is a stain on the glass which, I presume, is related to to the chemicals in the swimming pool water. Does anyone have any ideas about how to get this stain off?
Kind regards,
Matt
Pictures would help, it would depend on what the crystal is made of is it actually glass or acrylic ? I assume the stain is on the inner surface of the watch crystal other than polishing if the staining has only affected the surface with a fine abrasive paste, replacement may be the only option.
I would have thought if someone had  the movement cleaned they would have had the crystal dealt with at the same time.
Edited by wls1971
