A nice gift
PeterGe
A friend of mine, a retired watchmaker, asked me if I was interested in an old watch lathe.
Why he even asked I don't know [emoji6]
This what I received from him, an old Lorch lathe. Old but in good shape, no play at all. With a full assortment of collets. And the best part? I got it for free [emoji3]
What do you think? Still usable or just a piece of antique?
I actually was thinking of using it but first I have source a motor. Any suggestions for this?
Looking forward for your opinions.
Verzonden vanaf mijn iPhone met Tapatalk
It's very nice and very usable. The easiest option for a motor is an old sewing machine motor these can be picked up very cheaply on ebay and if you get one with a foot peddle you can have variable speed as well.
There is still an abundance of accessories available on ebay for these lathes but you have a good set of collets to work with its a Geneva pattern lathe you need to measure the collet's to determine if the lathe is a 6mm or 8mm version if you intend to search for parts at a later date 8mm parts are easier to source.
As it stands you should not have to spend a lot to get it running.
Thanks for the response. It is a 6mm lathe. I've already been searching around and it seems that the 6mm accessories are indeed a lot harder to find.
I've been looking out for a sewing machine motor on a local 2nd hand site, but no big offers there. So perhaps I should have a look on ebay. Any particular things I should pay attention on?
No any sewing machine motor will do there are thousands on ebay one with a foot pedal would be easier to use if it does not come with a foot pedal you will have to probably rewire it as most sewing machine manufactures use their own type of three pin power connector.
This is a example of what to look for,
http://www.ebay.co.uk/itm/SEWING-MACHINE-MOTOR-FOOT-CONTROL-PEDAL-BELT-FIT-LOTS-OF-OLDER-SEWING-MACHINES-/352101388920?hash=item51fae0d278:g:8yMAAOSw3h1ZVXGB
The best place to look for lathe parts is German Ebay they seem to get far more horological tools than anywhere else for some reason and quite often at a better price.
But I wouldnt worry about parts until you have it up and running and been using it for a while trying to jump before you can walk is very frustrating.
Yes but remember better 6 mm than 6.5 mm :thumbsu:
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
