What clock is this?
jdm
  • 4 years later...
Topic resurrection, the mystery is about to be solved. I took the mov.t out of the case to show it to my mentor Lino tomorrow. I believe all works, but it's super dirty so it will be at least serviced.
One question I want to ask here, the barrel arbors for the strikes have squared sections on the back too, although smaller that winding ones dial side. Is there a reason for that?
Please excuse the poor picture.
I have seen arbors twisted like that and it is due to someone forcing the clock to wind up more when it is fully wound. What makes him say it is Austrian? Is it to do with the strike works? At the moment I can't see anything that would change my mind. If it isn't to much trouble I would like to see more of the right side of the works.
No problem OH. I'm not really fixated about knowing who made it.
I found a signed inscription by a repairer from the the same year I was born: cleaned, rebuilt anchor and few parts.
That was the first time I looked close and put hands on a strike works and the like, upon superficial inspection it looks pretty good, some tapered pin has been replaced by twisted wire, and the hours (I believe is called) gathering pallet, that is the "anchor" mentioned above, is a bit lose on the square arbor, it appears to have been remade from brass. Master said I should shape a new one from steel, cutting the square hole with a small triangular tool, I'll see what I can do.
Then added that I should make a pervasive restauration including aesthetics, something with which I really disagree. Fortunately I was saved by someone coming to the workshop, the husband of her niece proceeded to make brass shims for a door hinge on the lathe and I quickly repacked it and left 😄
I can see by the pillars that I was wrong, these are so thick and plain as with Scandinavian movements of this type are shaped more like early longcase movements. The barrels are a give away too. The crown wheel to the verge is at a very strange angle, makes me thing someone has been at it. Thanks for the photos.
jdm what made your chap say it was Austrian.
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
