Speedy MK2 crystal
Mark II crystal is held in place by a o-ring . There is a groove in the crystal. The crystal needs to be inserted with a special tool. Hi failure risk without the right tool. Big risk of cracking the crystal.
Thanks for the help.
Tool for this is obsolete, is what I found.
I made a tool similar to above from the thick plastic movement holders on ebay for next to nothing. Nice and smooth inside, not damaging gasket. Fine layer of silicone, not liberally as in above diagram. Card cut out to push the glass to form a lip.
Worked a treat and glass is in first time, with no problems.
Thanks all.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
