Need Help With Stem Removal
This is a friend's watch. She needed a new battery and I offered to change it. When I removed the back, I immediately knew this watch had issues. Someone had put a sticker over the battery to hold it in place. When I removed the sticker/battery,the battery contact was bent and every time I attempted to put a battery in, it would pop out!!! I had to take the watch home and finally got the battery to stay in. Then I was unable to pop the back back on, so I had to use a watch press. I finally had the watch ready to be cleaned on the outside and scratches buffed out, I went to set it to the correct time and guess what.... the crown broke off!!!! OMG!!!
This watch looks a little different at the stem and I have tried to remove the stem by pressing a dimple, but no go. I'm afraid to put too much pressure on it and I need to make sure I'm pressing at the correct location. All I want is to get this watch back to my friend in working order!!!!! Thanks in advance for any advise!!!!post-278-0-00337400-1406587997_thumb.jpgpost-278-0-27811900-1406591310_thumb.jpg
Hi SuzyQ,
Welcome to the forum. Help is on the way!
And don't worry, all will be well. I understand your frustration but patience is all powerful when with watches!
So, in those cases, I usually use 2 tweezers to pull the stem out. One to push the stem release lever (usually through a hole or a little "button") -- I believe the hole on the left of the stem in the picture but it is not too clear -- and the other tweezer to grab at the stem proper and pull. This pull is usually by parts since there is not much room for a full pull of the stem. You might even have to wriggle the tweezers side to side...Be careful since you are working inside the watch! In any case, that's what I do. Maybe other members have a better way of doing it?
I hope some of this helps!
One question from the picture, is that a portion of the crown still attached to the watch or just the tube where the stem fits in? Is part of the stem still in the crown where it broke?
Robert
The center of the crown is still attached.Just the outside of it broke off. I posted a clearer pic of the watch. Thanks Robert. I have tried two tweezers. Can you look at the third pic I posted and see if you can help me??? Thanks bunches!!!
Is there an arrow or some indication next to the stem to the left front or is it simply the movement information? How about to the right between the stem and the battery? There is usually an indication about the right spot to stick the tweezers or a small sharp object to release the stem. On the other hand, it seems that you can still grab the stem by holding the portion of the crown still attached to it so the 2 tweezers trick might not be necessary.
Remember to puch the release lever and pull the stem at the same time...kind of gently.
Edited by bobm12
Thanks Bob for helping me. The writing is:
AL 21C
E P H
NO JEWELS
and the other is:
HONGKONG.
i do not see an arrow or indication where exactly to press. There is a "dimple" that I have tried to press, but no release. I don't want to press too hard since I am unsure if that's the place.
I think SuzyQ that it is more a hole or even the tip of a lever than a dimple (although dimple could work too) and you have to stick one leg of the tweezers in, gently and push. You will feel you are pushing something (springlike) down. At the same time the stem will become loose at your pull of it (it will detach). If that little end or bright point in the front left of the stem doesn't give, try another hole alonside the stem, gently, but look carefully first before you damage anything.
Thanks Bob. I've inspected the watch with my 20x loupe. I've gently tried several places. No go.... I've removed stems before so I know what the "spring" feels like. I'm a novice at this, but I enjoy working on character quartz watches I get from junk stores, online auctions, and yardsales and this one had been a pain!!! Murphy's law: if it was my watch, I would had it ready in one day!!! LOL I'm not going to try anymore tonight... maybe I'm just not holding my mouth right!!! LOL Tomorrow will be a new day!!!! :sleep:
Hi SuzyQ and welcome to the forum.
Sometimes the stems are quite stiff to operate. I would suggest that you use a small pair of narrow nose pliers to push the stem up and down from the running position to the setting position. When you do this look in the small hole to the right of the letters AL 12c and in either the setting position or running position a small lever with a dimple in it should appear. When it does, press it and the stem should come out. If that doesn't work, check other places, but remember that you will have to have the stem in the correct position to operate the release.
Thank you guys, I'm not too good at explaining! Great support! I wonder where Lee gets all the pictures! Amazing!
By the way Lee, I'm always visiting your blog, nice and to the point. Thank you for having it.
SusyQ, with all this help you have to have that stem out for sure! Tell us about your progress and please don't hesitate to ask away! It is a beautiful hobby.
    • For those who are, curious I broke out the macro lens and took a few shots.  I'm attaching four of them: Image 1 is from the watchmaker's side and generally shows the problem area. Image 2 is a detail view of the offending dial foot hole (called out with the green circle), the tip of the offending screw (orange arrow) and the blue line indicates the approximate position of what's left of the head of the screw (determined by using an oiler as a feeler gauge to transfer that measurement to the visible portion of the plate.) Image 3 is looking down the screw hole you can see the head of the broken screw at the bottom. Image 4 is the same, but with less contrast to give a better appreciation of the condition of that end of the screw. I can almost convince myself that I can see the remains of the screw slot in the head, but I have to use alot of imagination in that exercise. Heard and understood.  There does appear to be a steel locating pin that can be seen in the lower, right center of Image 1 (right "above" the oval shaped slot that is to the left of where the pinion/clutch parts of the keyless works nestle into the plate.)  As I don't see a way to remove that I'd have to keep it out of the solution and have even contemplated dropping a little paraffin on it to give it a "rain coat" of sorts.  As I missed that before I did the closeup photos, I feel that I'm going to be looking at this plate in much greater detail to see if there anything else I might have missed. The screw assortments seem like a good acquisition.  The eBay seller who has the donor movements I was looking at never replied so I may just take a chance and get one of those as well a screw assortment.  They do seem like they'd be handy.  I have to confess that the idea of fabricating the needed screws appears to some deep part of my soul, I also have to confess that I do not yet have either the equipment, or the skill to use it.  Perhaps one day, but that day has not arrived (and I have alot of pricey bits and bobs that I will likely need to get along the way.) I thought about this, but the dial foot screw doesn't seem to be wide enough to get the thing out if I could advance it into the hole.  I suppose that I could try and take it out in pieces (advance it as far as it will go, get in there with some sort of saw, take a piece off, walk it forward again, take another piece, etc) but that seems like alot of risk to the main plate. I need to examine the other screw to ensure it doesn't have a shoulder or something that would prevent me from doing something like that.  However, all that said, I've been unable to get the thing to move at all. In general, this whole piece feels like someone had it before me, did a bad job of working on it and ultimately just bunged it all back together in a haphazard way and passed it on to be someone else's problem.
    • Bulova Accutron 2181 - had an open coil I managed to bring it back into life. Longines 9L - not serviced just pics   Eterna-Matic Centenaire "61" - 1438U - not serviced just pics. Longines Cal 431 - not serviced just pics Lemania Cal 4650 - not serviced, just pics. Risieres Felsa 690 - not serviced, just pics. Felca Cal ETA 1080 - not serviced, just pics.
    • attached is the tech /parts sheet. .   Can one ask how come it’s full of water. After being told that the waterproofing was not guaranteed.  Problem being electronics don’t mix especially withe the power source being attached.  You may be lucky but I should look out for a replacement movement or working donor to rob the movement from. C720.pdf
    • I thought this may be "right" forum to post this. After 7 months out in Switzerland I got my Navitimer back from Breitling. I had sent it off since its 20 years old to have a complete overhaul done... Nothing major wrong, but I did notice this seconds sundial skipping thingy.... $1300 later and 7 months later, I notice the 'skips' are still here unless the chronometer is engaged. I would think this is likely the hand binding up and maybe clearance with the dial, but at any rate Im interested as to whether this is something I should be returning the watch to Breitling for and insisting on being fixed. See below - 1 minute or so of regular running and then 1 minute with the chronograph engaged.
    • A friend of mine just gave me an old pocket watch. The case is in very bad condition but the movement itself seems to be in a quite good shape. I can't identify which movement is this, since I have to find a missing winding stem. I attach few photos in a case somebody would be able to give some hints.  Thank's folks
