Hi,
I've an old chronograph screw shoulder cutter. One of the cutters has a screw end twisted off and jammed in it (came like that - wasn't me!). The cutters are, I believe, made of tungsten carbide. I'm assuming the screw is steel. A replacement cutter will cost more than the entire unit did, so I want to try a repair first. Options are drilling out the screw shaft, or trying a screw removing fluid.
I've heard good reports about Alum dissolving steel screws, but was wondering if it will act on the tungsten carbide of the cutter also and destroy it? Anyone any ideas? The same question goes for the fluids like the Bergeon one, if anyone has any experience with them.
I'm willing to take a chance on this, as the cutter is unusable and will have to be replaced as it is, so it's worth taking a chance on repair methods. Thanks for reading!
Mark
I say try it. Leave it in the alum solution for a couple of hours, you'll see right away if it's reacting (the steel screw will turn black)
A quick internet search seems to suggest that the only way to dissolve tungsten carbide is to use a really strong acid (sulfuric, hydrochloric...).
back and forth cold to hot may do it. Put it in the deep freezer then in a warm oven 105c/220f degree. It may work it loose. The two metals expand and contract at different rates. I have had some luck with this method.
Ok, I popped it into a warm Alum solution, and right away the cutter started to bubble, so it looks like it's not tungsten carbide after all. It's the original Bergeon model, the 30615.
That means moving on to Plan B. It's the 0.85mm cutter, so Ive got a 0.8mm drill bit to see if I can drill it out. There's not really enough of the screw sticking out to get a hold of it, so I don't know if a hot/cold approach will work. I'll keep it in the bag for if the drilling doesn't work out. Failing that, I'll replace the cutter. I got a great deal on the tool, so even replacing it will leave me at less than 25% of the cost of a new one!
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
