I take it the cannon pinion is slipping. I tightened a cannon pinion on a 6497-1 using a staking tool.
Basically, it involves setting it on a stump and then placing a punch on the pinion and giving it a tap with a hammer. You have to be careful about the alignment but I was surprised how hard I had to hit it to resolve the problem. The watch works very well now.
The job is fiddly but what watch job isn't?
There may be a YouTube video about this somewhere but I've not seen it.
  • 8 months later...
I had to tighten the offset cannon pinion on a Zodiac Sea Wolf 72B 17jwl and wanted to share the process, along with the tools that I used to do so.  This worked first time for me.
My first attempt at separating the gear from the wheel was by taking tweezers and using the wedge method but this was too uncontrollable and dangerous on the fingers and parts.  I located an old roller table remover tool that seemed to work fine.  It had a threaded post and nut to use for closing in the two arm jaws but threads were stripped.
Once removed, I used these two to tighten the cannon pinion.
DON'T FORGET TO LUBRICATE THE POST BEFORE PLACING THE CANNON PINION BACK ON!  I'm sure that this dry wear was the culprit in it being so loose at this point in time.
I also came across this cannon pinion tightening tool in an old watchmakers bench that looks quite handy.  I would attempt to use on a standard cannon pinion but like the control of the process outlined here for the offset style.
I hope this helps others in their encounter with the offset cannon pinion.
  • 1 year later...
Hi George C.-
I own a few Zodiac Sea Wolfs, one since new.  I don't work on them
I know one needs this cannon pinion tightening.  I have two others (much rougher condition) that probably also need it.
Do you do repairs for customers?  Would you be interested?  If yes, could you please tell me a price?
They all need cleaning and oiling also.
Thank you!
Jeff
[email protected]
  • 1 year later...
I am having a problem with an AS2066 with an offset cannon pinion but my problem is with power transmission (from the mainspring to the train of wheels), not the hands/setting so I don't think it is an issue with the cannon pinion.
I use fingernail clippers also. I also look though my stem collection for one that has a small enough spike on the end to stick inside the cannon pinion so I will not crush it while adjusting it with the clippers. I've always thought they should use a very small o-ring inside the cannon pinion for friction. It's a wonder they work at all. There is a very fine line between too tight and too loose.
I can almost guarantee it's the canon pinion. You can actually hit the little thing surprisingly hard with a 'little hammer' in order to tighten it. A staking tool helps.
My cousin ran a giant printing machine for a major newspaper in Winnipeg. One day the printer wouldn't work. He phoned the manufacturer and they sent a repairman out to fix it. The repairman, who had a stethoscope with him, asked my cousin to turn on the press. Then he walked up and down the machine listening with the stethoscope. After a few minutes he asked my cousin if he had a hammer handy. My cousin gave him a ball peen hammer and the repairman hit the press where he'd been listening with the stethoscope. Because it was already turned on the press started working immediately. The repairman left and after a few weeks the newspaper got a huge bill from the printing press manufacturer. My cousin phoned the company and asked to talk to the repairman about the astronomical bill. My cousin complained that all the man had done was hit the press with a hammer. The answer: 'Perhaps, but did you know where to hit it?'
Anyway, the morale of the story is: Don't use a ball peen hammer on a canon pinion.
  • 2 years later...
I've seen a few of these on ebay, can anyone explain how to use them?
Aslo this style
I also looked at this
However my clone jewelling tool is 4mm x 4mm (anvil) so will not work with this
Any ideas?
Aslo this style
Any ideas?
I have both of these . The top one has a needle to slide the cannon pinion onto that prevents it from being crushed while tightening the detent, mine i posted in tool of the day as a mystery  tool some time ago. The Bergeon one employs a different method of using impact on the chisel with a hammer. You can clearly see the v anvil that supports the cannon pinion on both. For that you would want to supply your own internal support such as a brass rod or needle. There is also another type like the Bergeon that has a depth stop for the chisel, i obviously have that one as well 😆. Bergeon also do the pliers some folk just make them from nailclippers and add an adjustable depth stop.
Edited by Neverenoughwatches
    • Hello, looking forward to participating on the forum here! I will mostly be listening and asking questions since I am an amateur hobbyist. I have most of the beginner hand tools and a Timegrapher. The extent of my tinkering consists of a successful Seiko 7S26 to NH36 movement swap inside an all original 1997 SKX007, along with a bunch of battery changes for friends and family. I have yet to tackle full disassembly and cleaning. Right now, I don't really have the budget or time to invest in a cleaning setup (even manual cleaning), but hopefully soon! I joined because I recently purchased a mechanical Timex Camper from 1994, and my searches for information regarding servicing and swapping out these Timex mechanical movements consistently led me to Watch Repair Talk. There is also a wealth of knowledge here about dial design, another area of interest for me. My other hobbies includes leather working (mostly small pieces, shoes eventually), crochet, sewing (would love to make clothing), design (especially type design), home espresso, cocktails, and tennis. I want to buy a film camera, but I don't need yet another expensive hobby involving last-century technology. Yes, I have ADHD.
    • HWGIKE#60 Accurist ETA 2390 Swiss lever, 21 jewels, full service A slim Accurist with a nice movement, eventless service, nice performance.
    • Hello and welcome from Leeds, England
    • Hello from South Carolina Barry...
    • Greetings, all. New to the forum and the red bar at the top of the screen said to introduce myself. Happy to do it. I'm an electronics guy by trade, pushing around electrons for the music industry here in Nashville.  This forum has already been a great resource. Thanks to all who contribute.  All the best, -barry.
