Balance staff turning without lathe :)
The spring should happily stay on the back of the day disc when removed. This has been floating around in a box for a while.
Yes I believe you will. Apparently there is another thin spring under the day ring, so be prepared for that to fall out of position. Thinking back, I don't know that I have ever done the M33 Day/Date automatic to see how that part is arranged. I have only worked on the M32 date version.
Wow. Thank you both very much, I couldn't have asked for better help. Now one question, to tighten the screw I have to remove the day and date wheels, right? Newbie anxiety. 😁 Regards Vasco
Doesn't look familiar. Have you checked Bestfit for the keyless works?
