Im searching for a replacement rotor bearing for my vintage Tudor prince 9050.
I am pretty certain that the movement in this watch is an ETA 2784 (If someone knows otherwise please let me know :-) )
The rotor is noisy, and after close inspection and a tightening of the rotor screw, I am confident that the rotor bearings are worn, causing a wobbly rotor.
My problem; I am really struggling to find a replacement bearing.
Does anyone know where to find such a part? Or if there is an alternative?
Thank you very much
Thanks for the advice Rodart and thanks for the welcome!
I have already tried a replacement rotor bearing specified for an ETA 2824-2, but unfortunately the gear was too small to mate with the mechanism of the movement which winds the watch; the push fit diameter of the part was correct but the gear diameter was not.
Thanks for the link, Its strange I have noticed that this rotor from Yukiwatch is specified to fit both ETA 2824 and the ETA 2784... So something does not add up based on my prior findings. I will contact Yukiwatch directly and ask for the dimensions.
Thanks again!
Hi Rogart,
So today I found out that the rotor bearing for the ETA 2824-2 is in fact exactly the same as required for the ETA 2784!
It appears that my initial visual judgement of the size was incorrect. When I measured both with calipers, they both measure 5.55mm in diameter.
I have fitted the part to my watch and its working perfectly and the noise has gone away!
Thank you so much for your help, its much appreciated.
