Hi
I found a copy of :
BENCH PRACTICES FOR WATCH AND CLOCKMAKERS
Henry B. Fried
As my luck would have it the pages on hairsprings I need the most are missing.
If anyone has a copy Can they scan me pages 32-44.
Thank You
Regards
Anthony
  • 4 weeks later...
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
