Hello all,
I have a funny feeling I know the answer to this, but need confirmation from some experts before I progress much further.
Back story: I recently took a chance on an unusual quartz divers watch on ebay that 'needed a new battery'. Upon fitting a new battery, the watch was still not working. So I decided to do a bit of investigating as a keen viewer of Mark's Youtube tutorials, I thought I could find out what is really wrong with this watch.
It has an ETA 955 movement, but it seems unusual in that it has both Day and Date. And from what I read, the 955 is a relatively robust and well regarded movement. But looking at online photos, and comparing it to my watch, I think I may have spotted the reason. The bottom of the battery compartment is open. No isolator and no arm to the negative. I initially assumed that the bottom was the contact to negative, but all other photos of this movement I can find show the isolator and contact arm.
So some questions please.
1: Is there actually two parts missing, or is what I have actually OK?
2: Is it repairable? Is the pad and contact something that can be placed in from above, or is it (the movement) likely to be damaged and need replacement?
3: If it needs replacement, are the Day and Date rings going to cause me grief, or are all 955 movements compatible with what I have and it's just a case of swapping over the electrical side?
Your help and assistance (and perhaps encouragement) would be greatly appreciated if I do need to do some work on it.
The watch in question is the centre one, with black PVD body.
Steve
The negative connection on the circuit has been snapped off and the isolator is missing.
Easy fix, undo the screws holding circuit board on, replace circuit board and fit a new isolator under connection on new circuit board.
presuming everything else is ok with movement you won't have to remove anything else and can even be done whilst still in its case.
Not all 955 are compatible. There are to make things more complicated? different heights . But you will probably only need a new circuit?
Not my finest repair, but from the posts above and some time looking at photos online, it was confirmed I was missing the isolator pad and negative contact. I decided to give it a try. For my insulator I used a clear disc of plastic that was part of my watch battery blister pack, cut into the neatest circle I could manage. The contact was a few strands of copper wire coated with solder, one end turned up slightly. Up turned end placed against the contact pad and a two second touch with the soldering iron. Not neat, but it works. Watch now on my wrist. I imagine it will break off at some point, so I will be getting a replacement movement or circuit, but no rush for it now. I'll have a little time wearing the watch before it comes apart again.
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
