Thread size of BB crystal press? Need help.
Halvis
Does anybody know what threads the die holder of the BB crystal press uses? I got a press on ebay, and the threads of the die holder turns out to be badly stripped. The press is of no use as it is now, and a new die holder is difficult to source.
If I know the thread size, I might be able to get some sort of adapter that lets me use standard Bergeon/Horotec dies. Hopefully.
Thank you.
Count the threads on a good picture like the one you posted, and go from there.
BTW I think that no adapter exist, but with a great cost and effort, one can be made.
Edited by jdm
38 minutes ago, Halvis said:
I was hoping that if I am really lucky, I could find something like this with the right lengths and threads. Probably not realistic, but worth a shot if I know the threads.
As mentioned above knowing the threads isn't difficult but finding an adapter is impossible.
They are either M5 or M6 . On my sternkreuz press i have M6 . They are the same as on a Bergeon press?
Someone could probably pretty easy drill the old one out with a lathe and put a new fresh thread in. On the old adapter?
Maybe even clean the threads with a threading tool could help?
As there seam to be a lot of old material from the die left on the adapter?
Like this? schneideisen-hss_800x600px-2083.jpg.dbada6d5ea96329687670dd5a3d86ed1.jpg
Edited by rogart63
17 hours ago, Halvis said:
That is correct. The threaded part goes into the press itself, and the dies are snap on.
Then it's more difficult to say which thread the die has? You will have to take a look at how the thread in the press look also? Is that damaged to?
If so it could probably be saved with a helicoil thread? The adapter is more difficult?
I believe the thread in the press is steel and the die holder is aluminum, so the die holder has suffered the most. The female thread in the press is full of material from the die holder and it is difficult to get a good look without taking the press apart. I dont know if I should take it apart and clean it yet, because things are not resolved with the seller. Trying to find out what options I have.
I believe my die holder is beyond repair. There is a gap (marked in the picture) that's not supposed to be there. The plate is completely stuck and does not sit straight.Selection_055.png.f089ebe4a698572774ff189fcabfddd7.png
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
