Hi all,
I have a watch with an eta 2824-2 movement. While the movement and second hand is still running, the hour and minute hands very often just stop moving. What could the problem be?
Many thanks
watchill
It sounds like either the hands are not quite properly seated (maybe enlarged holes or rubbing against something/each other?) or maybe the friction foil is missing, upside down or the dial is not set all the way against the movement plate?  mmm, interesting question.
Do they stop randomly or at any particular time? If the hour and minute hand are still in register, the cannon pinion probably requires tightening.
If it has a date or day register and only stops on the change do either one, the problem could be in the drive to these.
I had a similar problem with my wife's Longines, and sent it to Mark for repair. In a telephone conversation with him, his first thought - like mine - was the cannon pinion, etc. However, on later inspection, it seemed that there was uneven wear on one of the wheels in the train, which allowed the hands to turn part of the way and then stop - usually at the same position each time.
Just a thought...
I moved the hands now back and forth several times with crown on 2. position, the watch runs fine now since several hours. Is it possible that the gears are somehow unclean? h
When setting the hands does it feel loose? If there is not enough friction on the cannon wheel then you will get the symptoms you describe.
Only when I move the minute hand counter-clockwise, it feels loose. When I go clock-wise it doesn't.
The ETA 2824 (and some other ETAs) do not have a cannon pinion which presses down on the center wheel.. rather it is gripped by two arms and this provides the neccessary friction for transmission of power to the hands.. if the arms are not tight on the cannon pinion the the hands don't turn.
see picture of the dial side in this site..
http://www.chronometrie.com/eta2824/eta2824.html
The older movts like the 2452 have a three legged arrangement which is supposesd to grip the centre pinion in one direction, if fitted wrongly it can cause problems like you're having. The parts are interchangeable so this may be an issue.
so you are basically left with two possibilities..
1. Something physical with the hands, eg interfering with each other or with the the dial.
2. Power from the train not being transmitted to the hands. The seconds hand is directly driven by the train as the is no need for it to be 'set'.
Hope this helps.
Anil
In that case I believe your problem is with the cannon wheel. This is likely worn. I would just replace this as it is cheap enough and quite available. Then a little lubrication and the problem should be fixed.
You should always feel resistance when setting the hands. If there is no resistance then the cannon wheel (or cannon pinion on other watches) is too loose.
    • I had it in a little jar in a double bath at 60ºC in a more or less super saturated solution - some crystals came back out of solution as it cooled. Heat was really the trick - When I started at room temperature I could see a bubble form on top of the old stem and just sit there but when heated there was a constant stream of bubbles
    • Sorry to bring this one up again: You mention you got new springs, dare I ask where? I haven't been able to find any but those for the manual version. I cleaned and wound the mainsprings in my 2427 using a modified M6 washer and the crank from a winder, but they were a bit coned, have a bit of a kink in the spring where it meets the end of the bridle and the resultant amplitude is quite poor. 250, maybe a bit higher, on a full wind. Confirmed that this is how the yoke should look when taking apart a 2428 for parts. I saw a post that you've left the forum. I hope that's not the case. You've helped me more than once and it was very much appreciated.
    • I spent a few hours with this 3135 Rolex yesterday, and as we can all see, the reason the date and time can't be set is obvious. Had I known this—I was expecting a dislocated yoke—I would have refrained from running it, as we have no idea where those broken-off teeth are located inside the movement. It could very well explain the funny timing machine readings. Hopefully, the damage is limited to the first (there are two) setting wheel, but we shall see as the disassembly continues. It's a good sign that the sliding pinion teeth seem to be intact. It also raises the question of how something like this can happen. Perhaps too little or the wrong type of grease in the cannon pinion, and when it became difficult to set the time, the crown was turned with force and too quickly. That reminds me of another movement (years ago) where the cannon pinion was way too tight, and I still tried to set time, which broke off the teeth on the minute wheel. However, it was a scrap Vostok, so no real harm done.
    • Can anyone help with the identity of this movement please. Books i have searched up to now include 1 and 2 of Bestfit 1965, Bestfit 101  1956, Flume 1958 and 1972 and catalogue officiel 1955. 24mm plate  which lands around 10.5 - 10.75 lignes
    • Welcome to the forum. Here's a good site that in your case shows the original along with the modern alternative. https://www.emmywatch.com/db/movement/gruen--490ss/
