Hi All,
Maybe a bit of a long shot here. I recently bought a crazy looking 1971 Zodiac Astrographic watch at an auction. It needs a service and I have found some info on the internet about it. However, the mineral crystal is very scratched and I feel I should replace it. However, as you will see from the photo, the crystal seems to have a chapter ring and a central emblem incorporated or glued on the inside. I can't see an obvious way to remove it and save it. the appropriate Zodiac service manual describes how to replace the crystal, but makes no mention of the chapter ring.
Has anyone ever worked on one of these???
Thanks in advance
Nick
Well is it glued or printed on the crystal ? It looks glued to me... You could try and remove the crystal safely and then unglue the emblem with some substance. Something that dissolves the glue but won't harm plastic or any other hard materials.
Afterwards you could use transparent glue (the one used for fixing crystals onto watches, usually vintage) and attach it to the new replacement crystal.
Thanks Chopin.
I have been researching all evening and found that the crystal is actually a part from Zodiac with the chapter ring and central emblem glued on. I am trying to trace one now.
Thanks again.
I spotted a couple on the bay earlier while looking for zodiacs they wernt  cheap tho if I remember
This guy makes his own but the process sounds a bit involved but the results look good,
http://www.crazywatches.pl/zodiac-astrographic-tank-sst-mystery-dial-1972
And this company make them but they dont mention the price,
http://www.ultra-vintage.com/custom-shop/
so new old stock off the Bay maybe your best option the crystals are glass so maybe a local optician could polish them out.
Wow, how did you find these crazies?? Thanks so much for that. I'll keep their details safe. As it happens I have found and new old stock on Ebay, made an offer that was accepted.
I really appreciate your help.
I dont know I have a knack for finding obscure sites on the web but can I find the chuck key for my drill No! is it where I left it No! has someone other than me been tidying up Yes ! errr:pulling-hair-out:sorry I needed to vent, off to B&Q now
LOL
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
