Maurice Lacroix Chrono Re-Finish
Hi,
Real nice forum :) Just thought I'd post up a thread of a re-finish I'm doing on this Maurice Lacroix I picked up recently. Here is the watch:
Overall, it was in really good condition, even came with 4 full size spare links which looked like they were brand new and had been taken off the watch at purchase and never used since. However the bracelet had seen some proper use. The case head isn't so bad, but does have some marks on the top. The sapphire crystal is flawless as I'd expect it to be. It keeps good time and the functionally the watch is perfect (it uses the ETA 251.262 quartz movement). The lume is amazing and the best I've seen in person on any watch. It charges very easily and lasts ages (after a 2 minute charge under a desk lamp/phone LED flash it can still be read like 4 - 6 hours later)
But the bracelet! So I purchased a watch/metal polishing kit off ebay (this one to be precise). The entire watch has a brushed finish, however it's a really really fine brush - closer to the polished look, though you can clearly see the brush marks. A fine satin finish I guess is the best way to describe it.
Here's what the watch looked like when I got it. Note that the 2 links either side of the claps links are the new ones - so this is the finish I was/am trying to match:
And here's after going over the scuffed links with the co**BLEEP** and then fine buffing ball.
Although the finish is good - I've seen some watches with this level of "brush", it's not a perfect match to the OEM finished links - I guess I need a finer, higher grit buffing ball to use with the dremel. I will eventually tackle the head once I can get a better match on the finish.
Does anyone know if the same effect could be achieved by maybe polishing the links first, then using my fine buffing ball gently ? OR would it be better to find a finer buffing ball?
Cheers!
Welcome to the forum suj, you will find this a friendly place to be a part of. There are folk here with diverse skills, so will undoubtedly pick up some good information.
That's a fine job you are doing refinishing the watch. When I refinish watches with brushed finish, I always polish them first to make sure that all the blemishes are removed before applying the brushed finish. I use very fine wet or dry abrasive paper or a fibreglass pen depending on the the effect that I want. Whatever method you use, ensure that the striations are parallel and follow the contours of the watch and/or bracelet.
Thanks guys.
Yeah someone else also said polish the bracelet (to a mirror finish first) and then add the brush effect. When I've figured out how to get the finish I'm after I can work on the case head, which will make the watch look like new once it's done.
Thanks guys.
It takes a fair bit of time and effort to get the best finish, but it will be worth it. It would be a good idea to pick up a really cheap stainless steel watch with a stainless strap to experiment on. That way you can try out different grades of abrasives and polishes to see what suits you.
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
