Screw driver help
Douglas1701
2 hours ago, Douglas1701 said:
Could someone tell me the smallest screw driver to the largest screw driver i need for pocket watches and wrist watches?
Thanks
Hey Douglas,
Welcome to the forum.In my experience, You'll need these 5 sizes to get anything done:
0.60 mm Pink
0.80mm Yellow
1.00mm Black
1.20 mm Red
2.00mm Green
There may be a few brands that use screws sizes on either end of the spectrum, but these will get you through 99% of wristwatches and most pocket watches.
JC
Edited by noirrac1j
5 minutes ago, Douglas1701 said:
What about the .00 and .5 ? I ordered a set today that had those in it up to 1.5mm.
Thanks for the help.
The 0.5mm will work in place of the .60mm and you'll see the difference when you use those sizes. I suggest you use the screwdriver that is closest to the slot size to prevent slipping. This happens anyway, but will be reduced if you use the proper size screwdriver. I remember I was tempted to use smaller screwdrivers on the larger barrel or winding wheel screws and simply messed up my small blades when they came up short on torque and slipped. Lesson learned!
JC
Edited by noirrac1j
The reason i bout them that small was because i want to restore my gransfather wrist watch at some point in the future....there was a screw so small i could barely see it. That being said, the set was the only set i have run across that had that small of sizes...figured i better grab while the grabbing was good...it was a swiss set of 7 for $12.no one bid on it but me and one other.
doug
Edited by Douglas1701
doug
What type of watch is it? Can you post a picture or the caliber?
JC
2 minutes ago, noirrac1j said:
Its a beauty! We'll get that going...I'll help you in any way I can and so will the other fellows here. They're all top notch. Have you ever disassembled a watch before?
JC
No, just started learning and getting tools together...got a pocket watch movement on the way to start practicing on.
OK that's a good plan. You'll need good lighting (either regular bulb or fluorescent/LED type) and quality 10X loupe (Bausch and Lomb or something good quality) and a general magnification visor with 4X. You'll also need at least one movement holder and a mat to work on.  One more thing: a good set of tweezers! I got some from Ebay that are decent, but they must be Swiss because the quality is the best and you need good tweezers to work.
JC
2 minutes ago, Douglas1701 said:
Gonna start marks videos as soon as I can..might be awhile though.
Perfect. That's just how I started and I've done many, many watches since then. Mark's videos are the best and his technique is superb.
JC
Edited by noirrac1j
20 hours ago, Douglas1701 said:
Gonna start marks videos as soon as I can..might be awhile though. Ive been making some of my tools to speed up the process. So far i made a balance tool and i should finish the oiler station tomorrow or the next day.
That is a NICE balance tack...much nicer than a metal one.
J
    • Did you have a look under the ballance? Often the movement maker/number is hidden there.
    • I wonder if 9415 is based on a base oil of 941? it's interesting what questions bring and the tech sheet answers it's the viscosity of the base oil. Then the impact? There is something we're missing here for that which would have a big influence on all of the house image above is 9514 image below is 941.then always interesting when specifications do not exactly agree? They ledge above for 941 indicates 110 viscosity but the image off the spec sheet is slightly less but I guess close enough   my understanding of the concern of too much 9415 is as we know the loss of amplitude. But why do we have a loss of amplitude? So impact it's basically oil should be very slippery. But what about non-impact? Like the edges of the escape wheel? Another thing that comes to play here is the shape of the escape wheel itself. Notice on the last a more vintage escape wheel with just a flat surface whereas the modern escape wheels usually made out of steel versus grass much much thinner their contact areas greatly been reduced and sometimes I think there even slightly curved. So is it conceivable at everything that isn't a flat surface on impact is going to be sticky? So this is where the shape of the escape wheel will have a big impact literally on how slippery things are. Oh and for all of you obsessed with worrying about too much 9415 I never worry about it because typically I'm doing pocket watches and it doesn't seem to be an issue at all. on the other hand I'm much more concerned about a watch that keeps time for 24 hours as opposed to the concern of the group of keeping amplitude for 24 hours. Then yes some pocket watches have steel escape wheels and do look like the escape wheel on the right.
    • your balance wheel looks interesting in the watch and because it's at an angle it's changing things a little bit. in other words they hairspring is not centered between the regulator pin in the boot and I also noticed your terminal curve is lacking apparently by design? Because if you look in the second image you'll notice yes there's a terminal curve but not as aggressive a one as you normally see on watches at least most watches.   then in all of your images it looks like the boot isn't quite back where it's supposed to be? out of curiosity how did you remove your balance complete and clear the regulator pin? then just in case you weren't aware it rotates out of the way so you can remove the balance complete without bending the pin. Then it's rotated back exactly 90° and yours looks like it's off by just a little bit in the original image and I'm assuming that you just been the pin out of the way? it's always interesting in horology is the variations in the things. Like the image I have above does have a terminal curve but not the most aggressive and yours is even less but that is the way the watch was made. Then the spacing between the regulator pin in the boot should be relatively small basically if you had two pieces of the thickness of your hairspring that's how much space should be there like in this image. But oftentimes watch manufacturers do not necessarily follow the rules
    • Yep i can see where you're going with that one Rich.  Sooo now that I've frightened the OP into submission 😁. Chief i do apologise for some reason unbeknown to myself I'm in a happy silly mood. So seriously to identify the movement lets have a look at the dial side, learning this part is straightforward, just need a little logic and something called the # BESTFIT BOOKS # . Or the other non American equivalents.
    • I can definitely see elephant and aardvark and possibly some sort of bird with a large beak 🤣 anyway I'll have a go of getting it flipped over tonight and send some pics
