Suter Aquamaster
Hello, Newbie here, I am trying to find someone who could service and replace the glass on my Suter Aquamaster watch ...can anyone help at all ? I have taken it to several jewellers but they cannot seem to replace the glass as its flat with a bevelled edge ...kind regards
Thanks for the info, I am going to send it to them for an estimate ....kind regards ..Paul
Hi, Unfortunately, despite sending the watch to them for a quote for replacement glass , the watch got serviced and  I was  then advised the glass was not available ? ..... so I am back where I started .... is there anywhere else I try to get this glass replaced ? from what I am told  the yellow rim around the edge of the case is actually part of the glass its a specific glass for the watch ...... There must of been thousands of these made, so there must be one out there some where ...but where? ....kind regards
This a new make to me. However have searched the world wide web and there seems many different calibers of this make of watch.This glass I guess is an armoured glass hence the gold rim being part of the glass. I am surprised that a generic glass can not be found that fits.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
