Can someone advise on which pin/friction pin/ screw pin or other fitting I need to connect this bracelet to this watch. I can do the measurements, but just not sure what part I really need. I was thinking I can join using a screw pin. See attached image
Screw pins are really not that common and world require threading. You can probably use a straight pin with collects both side, or a stepped one with a collet one side. Cousins UK has a good assortments of these.
