M0.5-M0.6 thread taps and drills?
szbalogh
I got some small 13'" movements with extra tiny screws, some of them have bad head so i want make new ones to replace them.
On the other hand i want also make a swan neck regulator. For this i need a long regulator screw with M0.5 thread.
To the point. Where to buy (for cheap fo course) thread taps/dies. Or how to make them?
You need to find model engineer clubs for this type of thing. To start with you will need a lathe and I should think it needs to be able to undertake screw cutting. Do you have any model engineering shops around you? You could search the internet, have you tried ebay for the parts.
You can buy 0.6mm taps and threading plates from ebay
http://www.ebay.co.uk/bhp/watchmakers-taps
If you want 0.5 or smaller then I've only ever seen really expensive sets. If you really want to go this small then buy some hairspring stud screws, choose one the right size, file flats on it and taper the end, then harden and hold in a pin vice to use as a tap...
https://www.cousinsuk.com/product/balance-screws-wristwatch1?code=S37250
Thank You, i will look around. By now You should know that i have a professional lathe ;)
Those sets are really expensive, i also found some.
I was also thinking on something You suggest. Using a hardened steel screw as a thread drill to make the thread in a softened plate and then harden it to get the tap. A "how to" would be nice for this. Those little screws i mentioned are so hard, they blunting my screwdriver without getting any scratches on the black polished head.
  • 4 weeks later...
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
    • The case number should be on the back.
    • I agree, I call it a pallet fork for two reasons, it was the name used when I started watch repair both in written documents and on videos and calling it a lever causes confusion as seen.  Plenty of other examples where there's more than one name. What do you call the opposite side of the movement from the dial side?  I've heard you call it the watch makers side.
