1920's pocket watch help
AP1875
Hi, my friend just dropped round with a pocket watch he wants me to take a look at it. At first I thought he meant it just needed a service, but it is in pretty bad shape so I thought I'd ask here for some advice on how to approach this.
Can anybody identify the model from the pictures? I've looked online and I can see similar watches but not this one. It seems to be some sort of Dennison. I googled the markings A.L.D 267080. Movement says Swiss made 17 jewels and doesn't look too different to a 6497.
Will parts be available for this? Its missing a crystal, minute hand and at first glance you can see the hairspring is damaged
The watch has been passed down through the family. It says on the back 'from mother on his wedding morning August 4th 1924' . It now belongs to his mother who is not too well and would like to get it working to give back to her.
So before I take it apart, I'd just like some advice on how to approach this.
Thanks guys
Firstly, 7 jewels not 17! And it looks like at least 2 of them have gone awol, from the balance cock.
It's a 9ct Dennison case, and as often happened in those days, the movement quality is somewhat lower than the case. When buying a watch, you chose the case and probably took the retailers advice on which movement to have fitted.
The hairspring is a bit mangled. I can't see if the stud is still attached or if it has broken off. If the former then with time and a sense of humour you stand a chance of re-shaping it.
There appears to be a movement makers mark next to the winding wheel which I can't read... possibly Buren?
If you can find a calibre number - maybe under the dial, then I would try to track down a spare movement from eBay to use as a donor as you will struggle to track down the jewels.
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
