Hello. I'm having trouble with this watch. First of all does this type of pin have a certain name? I messed up with install a pin and it broke, so I want to get a new one if I can.
http://imgur.com/a/jWxXT
http://imgur.com/a/sR291
http://imgur.com/a/4lrvn
Sorry about unclear picture, there's a little cut on the top, but it's not screw, just a cut. and as far as I see, it doesn't have a sleeve either.
This might be an unusual one, but I'd like to know if there's a terminology for it.
Also, I was able to come off the pin no problem, but then I can't put it back.
To me, it just need to push it back with pin puncher and hammer. But the thick part didn't fit and I accidentally broke the head after all.
Maybe I just did it for wrong direction. I set the pin from opposite direction of the arrow just like common cotter pins.  I'll check out an other link tomorrow.
Thanks for reading.
welcome to the forum.  " a pin pusher"  that  would be a "pin punch"  they come in sets.   you will find one punch with a diameter less than your pin. or you can make one..   carry on; - good luck. vinn
what you broke i think is called a split pin.
The arrows under the links show the direction to remove the pins.
When removing, the end with the split comes out first when pushing in the direction of the arrow.
Thanks everyone! Although I haven't had time to try yet. I'll write it when I did.
Yes, because it didn't look like one of those cotter pins which are familiar with me, I was wondering if there's other way to set it.
  • 4 weeks later...
Finally, I had time for it and was able to install them. The thing was, it's not one of those common cotter pins, not flexible. I needed to tighten the tips with plier beforehand.
Anyway thanks for the help!
    • I also still use my cheap first set of screwdrivers. I replaced the blades of the smallest (0.6mm) with higher quality once I had bent a few of the originals, but beyond that I have been fine. Note though that I do not work on any remotely valuable watches and most of what I deal with are in a truly terrible state, watches that have been banging around in kitchen drawers or toolboxes. So my concern for screw head slot integrity and scratches is usually not very high.  As for a loupe - you won't need anything powerful for an ST36 that is new. You don't need to do close inspection of balance pivots because they will not be worn out, and a 3x or 5x loupe is perfectly sufficient to see the oiling. I don't have any microscope or powerful magnification of any sort. I just use cheap loupes. But again this would be different if I were working with more valuable watches. And if I had equipment to burnish pivots, then I would get a microscope to check my work.
    • I've recently switched over to using a x2.5 -x3 eyeglass for disassembly and some larger part assembly. It's interesting to see how accustomed and trained your eyes become to that way of working after using a microscope for years. And pick up and work at eyelevel when possible. Personally I would stick with and learn to use regular oilers efficiently.
    • I remember playing with asbestos wire insultaion when I was a kid (remember the cool fluffy white stuff?) and I've been breathing fine dust particles in my woodworking shop for years, so I'm probably toast either way, but I don't want any of this radioactive dust anywhere near my kids.
    • Its good to understand how and why demagnetisers work. These two pieces of text explain in basic terms how ferrous metal is affected by magnetism and why they can retain some of those properties.  The cheap demagnetiser is actually a magnetiser,but is used in a way that can remove the weak magnetic properties that a steel has gained through magnetic field exposure.  As steel is drawn further away from the device, the magnetic fields around it become progressively weaker and more -irregular- . This causes the disruption of the atomic and subatomic alignments within the steel that make it magnetised. So also moving the steel  through different orientations as its pulled away could actually improve that process. I still use my first cheap set of drivers, I notice very little difference in the way of feel between them and a set of preowned Bergeon I use, blade quality is more important. Tweezers have more variables, but again they don't have to be expensive to work well. My most used tweezers are my cheapest, but then I never use any pair that I haven't modified in some way.
