valjoux 7750 cover plate question
Danh
Evening Folks
i was not expecting this tonight whilst swapping a watch case on one of my watches, and before I physically investigate thought it wise to ask.
whilst replacing the weight finishing off the watch tonight I realised the screw was not tightening properly, or so I thought.
on examining the chronograph cover plate it appears the post for the weight is loose and turning that the weight should tighten onto.
has anyone seen this before please?
is it a usual thing to happen or has the post on the cover plate snapped and I need a new cover plate?
as ever thank you for any replies
Dan
The bridge with the oscillating weight retaining screw thread post, this can be replaced, a new one pressed fit, but in your instance, you would be better off replacing the bridge itself.  I have only come across the problem you are having once, and I simply replaced the bridge.
I did look closely at the bridge from the underside, and it looks like the thread post is renewable, but have never seen the post being sold on its own before.
Thanks for the reply, I have had a closer look without dismantling and it appears that the Jewel under may have broken also.
i have emailed May to see if the bridge is in stock (8500), not sure where else to source one if May does not.
Ah thanks, I take it you are stateside?
Edit, just noticed its an English site that, have you ordered from them before?  I'm always open two other sources for parts :)
Its little hard to navigate that site, but worthy of a bookmark :)
Edited by SSTEEL
Hi guys,
I believe the transparent jewels are better quality since -- don't quote me on this one, it is from memory! -- the white transparent jewels are cast and the red are pressed from "dust" like particles. They are both man made "rubies".
Cheers,
Bob
That's an interesting article Bob but it doesn't actually explain the difference in the colour of the jewels, it is referring to the difference in clarity. Polyrubies are translucent, almost waxy in appearance, the synthetic rubies are clear, like red wine. Both are red in colour.
In my own watch mechanicing endeavours I have encountered red, blue, and white (or clear as in colour, not clarity) jewels. Red jewels are rubies. Blue jewels are sapphires. And white jewels are diamond, these I have only encountered as balance end stones on much older higher end movements. Some sapphire jewels are very pale in colour, and because they are also very thin, they can look colourless, thus easily confused with diamond.
Diamond is of course carbon. Rubies and sapphires are essentially the same as each other as they are both aluminium oxide (or corundum) with the difference in colour resulting from trace elements within the crystal structure (chromium in rubies, and nickel, iron, copper, etc in sapphire giving rise to colours from blue to yellow and green). As sapphires and rubies are effectively the same stuff, with the same physical properties, I can't really see why one should have any advantage over the other, except maybe cost, and that may simply be due to economy of scale of manufacture. Maybe the use of sapphires is to create the perception of higher quality since they are more expensive? Who knows.
The most common use (that I have seen) for sapphires is for pallet stones in older watches. Then for balance end stones, and this may have been to create the impression of diamond (which is harder and more expensive) in this highly critical part of the movement. Sapphire end stones are a pig because their lack of any strong colour can make them very difficult to see, especially when they are in a jar of naphtha for cleaning (thankfully not how I do it any more). Diamond end stones tend to be less of a problem from a visibility point of view as they are usually in a setting.
I have also seen sapphire pivot jewels though. They have tended to be in more modern movements, but I have as yet to find any convincing argument to suggest that they provide any practical advantage over rubies.
Thanks Geo,
it was something that I looked into a while ago when I thought that maybe someone had used glass for end stones on an old pocket watch. Turned out it was diamond, and researching it shed light on all the other colour variations that I had seen in pivot and pallet jewels.
    • So that is what the last person to work on this movement appears to have done.  There was a "wad" of adhesive material in the vicinity of that hole when I took the dial off.  I was hoping to take the high road and fix the issue in the work I did on this movement. I wasn't sure if I was imagining things or not when I looked at the screw hole, but it does appear to be somewhat distended.  I had not considered the posibility that someone had forced a screw that too big in there.  I had wondered about using a technique I've applied in other applications (where the screws are in the same scale as human hands) that involves counter drilling the plug with a  reverse threaded tap.  When I've had to do that in the past, the screw has generally caught and backed out from the torque on the tap (instead of yielding and letting the tap bore into it.)  I don't like doing that, but it's saved my rear a couple of times, but the smallest bolt I've tried that on had a 5 mm head.  This is an entirely different ball of wax. I am still contemplating disolving the screw with alum, even if that means I have to stick the dial down with double sided tape until I gain the skills to actually replace the screw.
    • Hi Thomas, you should be able to find the right (or on close to beeing) in a Ronda or DCN balance staff catalogue. Cousins uk have those available as a download.
    • Hello everyone. My name is Cees (pronounced "case"). I have been working on watches for a few years now. Got down the rabbit hole when I started watching "how to" videos on watch repair when my watch broke while on holiday. I'm not interested in collecting watches, but purely in the technical side. I love fixing them and also love collecting the tools I need (or might possibly need one day...).
    • The movement is FHF, something like this. But it will not help much to find stem.  Sometimes making one is easier
    • I think they all have their pros and cons, the one I suggested is a threadlock loctite product (Loctite is now owned by Henkel), In general I use the current one that is recommended on their Loctite page (link here)   I use blue (243) for the actual crown the (stick is actually 248 which is the stick version of 243), like I said it is very convenient for using on stems. Blue holds the crown for everyday use, but can be removed if you need to with a little heat. I use the red 277 for things like stem extensions where I have no intention of ever removing it. The purple I don't use (but I have seen some youtubers use it) as I think the blue is removable so why take the risk on a weaker product.   This is interesting, and a useful bit of information to know 🙂
