I'm baffled. It happens a lot that, but this time there is a reason. I have an old Longines movement that I bought in bits, like the most complicated 3D jigsaw I can imagine, and included in it is a mainspring and the two halves of its barrel (is that the right name?). Now to put it back together I need to wind it, but how do you tell whether a spring should be left or right hand wound?
Allied to that is that I don't have a winder of the right size but it's knowledge I'm after as well as kit.847df2a150cab4e8616f2ed8261ba4d4.jpg
Try fitting the arbor into the barrel and which way it fits will tell you which way round the spring should go.
Thanks@oldhippy, I'll have a good look at it.
As OH says, work out which way up the arbor fits in the barrel, Then look closely at the hook on the arbor (with a loupe) and you will be able to see which way the spring has to go so that it stays hooked on to the arbor.
Thanks Marc
Sent from my brain using evolution and electricity.
