To Those of you with CousinsUK Tubed Daylight lamps
SSTEEL
Have any of you come across problems with the wiring of these three tubed daylight lamps?  I have two, and a little while ago one of the tubes went out on one of them, and then this morning, a tube went out on my second one.  I had originally purchased some new tubes from cousins, but upon fitting it in the first lamp, it didn't work, so tried a known working tube in the slot, and nothing, so a faulty wiring was suspect.
Fast forward to this morning, back at work, and set about renewing the tube in my second lamp, but low and behold, its another dud, new tube won't work, or known working tube swapped across to the slot the tube wasn't working.  So obviously a faulty batch of these lamps, or a common problem?
I will be ordering those LED lamps that Mark has soon, as I've never been quite happy with the heat these tubes give off anyways.
Just to note, my lamps are almost 4 years old.
Edited by SSTEEL
Sorry to hear that Micky. From what you are saying, it seems to be the wiring. Maybe after 4 years the insulation went boom...I'm glad you found this fault and now everybody reading this knows better.
I hope someone can also enlighten us about this problem.
Cheers,
Bob
I just looked through my paperwork for these lamps, and now realise, the first lamp I got was from eBay, its exactly the same as the ones Cousins sell.  I read my notes that I contacted the seller at the time about the problem, and they said to return the lamp back to them, and they would replace for free, however I was so busy at the time, I put up with it, and ordered a second lamp from cousins.
Now the cousins lamp has done the same, it has to be a manufacture QC problem in my opinion, both lamps have the same markings, made in China etc, so no doubt from the same supplier.
Sounds like they have you between a rock and a hard place SSTEEL.  <grin>
On a lamp related question.  Which lamp(s) does Mark use?  I bought a LED lamp off Amazon that is okay for light output but it comes from a rather small area.  So the light is easy blocked by head, hands or tools.  Just curious if you knew the specific lamp Mark is using or you had found something similar.
I remember HSwalsh from my days, never heard of the others.
I used to go to Mahoney associates.
58 Stapleton Road
BS5 0RB Bristol
City Of Bristol England
0117 955 6800
i don't know if there still going it was a family concern and they where excellent.
The other was Southern Watch and Clock Suppliers Orpington Kent
Mark has posted about the led lamps, they were from cousins too.
    • Couple of Oris in there , early Oris were pretty small , around 28mm , the first 2 could be 45x or 49x series calibers. The Unicorn might also be an Oris, to know that these will be pin pallet watches if there is no jewel count on the dial. The other 3 will be much the same. The Oris are ok and have some value, as far as pin pallets go Oris were very good as thats all they were allowed to work with for a long time, so they made sure they got the best out of them. Its good to inside though, at the most basic level of inspection of an Ebay sale at least you can see if anything is missing inside, otherwise its just pure luck. Ask the sell if he will add some pictures of the insde for you to privately look at.
    • What I've found with Facebook groups and yes i am in a few , its good to have more than one source of information on specialised areas such as lathe restoration or just military watches etc. They dont have the same ethics that we have here, we all seem to look out for each other here, a good close knit group that encourage new members and each other daily. We have a laugh sometimes and really help each other out and support each other. All the support i received about my mum was so kind, i wouldn't have got that anywhere else. A lot of these facebook groups are full of aholes and sarcastic gate keepers. I consider our forum to be very unique, but the subject of # if it ever Dissappears # honestly i think does need addressing . We're really just after a connection site Michael not a full function chat group. Just a way to re-connect if something happens. But the other big thing is all the stored information how that can remain accessible.
    • Facebook is a big NO from me. I have nothing to do with any of these sorts of places.
    • I for one would have to pass, I'm not joining Facebook.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This might be helpful for you.  704789946_TZIllustratedGlossary(2).pdf
