Cheers mates!!
Maybe a stupid question, but...
Started taking apart my first movment yesterday, and found out that there was no "balance stop lever" inside the ETA 2872 I started with. Is that correct?? Should there be on??
I have read somewhere that movements above 2750 Doesn't have the hacking  function.  But it's easy to put the little balance stop in if you like?
Great Robert!! Of course, the balance stop lever makes the hacking function. This watch here is the yellow Antima from the 1970, and this have no hacking  function. So that is cool.... Thanks a lot Robert!!
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
