Hello
Does anyone have a technical document over this movement?
I am having a bit of trouble with the date change and wonder if i have lubricated, or not, the correct parts.
During dateshift the datewheel stops halfway thru, and i have had problems that the whole movement stops randomly until i adjust time a bit.
Any suggestions a welcome
//Magnus
Lubrication and date change mechanism is on the 27th page of ro63rtos's link. I suggest take down the dial and check all mechanisms how they work. You will see where it is wrong.
  • 1 year later...
Hello
//Magnus
This also happened with me on the very same movement. Please check the region where the date ring runs on the base. I wonder if there is a screw protruding through from the pallet fork cock? This was the case with mine. Hope you find this to be the case, easily resolved by checking which screw you incorrectly placed. Regards Deggsie
