Hi Folks
would anyone know the novodiac Spring size for the ETA 2836 please.
cousins list them as 1.25mm 1.45mm 1.60mm and 1.65mm
as ever, many thanks for your help
And finally life has allowed me to return to this.
so back to business
does anyone have a tip for fitting these Novodiac springs, there is a tool available, but tips from pros are often much better.
thanks in advance
Dan
Hi Dan,
You can hollow (make a little dome like indentation/hole in) a wood stick (peg) to the right dimensions so that the edges of the stick match the spring diameter. That would be the tool for inserting the novodiac spring...if you don't feel comfortable using two tweezers...which I do.
Cheers,
Bob
Correction Dan, the diameter of the stick/peg "indentation" is the actual diameter of the spring housing....i.e. the spring will "dome" into the peg and as you rotate it, it will get into position and lock in (there is a groove where it fits in).
