how to set certina 25-652 date wheel
Hi All,
I am trying to set the day and date changer wheel on a 25-652 Certina. I can get the date to change no problem, it's the Day finger that is out of position and seems to jamb on the day wheel. I have tried several permutations but still happens.
Cannot find and service notes for this Calibre.
Any help greatly appreciated.
Cheers, Keith
    • Back home...printing now.  Will report results
