Miyota 6L02 - how to swap the day dial
By rjenkinsgb · Posted
Definitely send it back! I'd guess there is an improperly fitted or adjusted friction spring on the seconds hand drive, a similar principle to those common on centre seconds pinions. Engaging the mechanism presumably puts more load on the gear train and damps it down. I had the same jumping seconds hand effect with a sprained centre seconds spring; they damp the hand movement and prevent it jumping or flopping around within the mechanical backlash of the gear train. -
Yes 19mm is the widest. Very few vintage Seikos of the era have wider lug width.
You've confused me here Rob, are you saying watches with the encircled T symbol on their dials are not using tritium lume ?
