Want To Learn About Oil
Can anyone please explain  the oils used, Is the different numbers for viscosity? maybe a good table will help with witch oils to use on witch parts and WHY? Is there any cheaper alternatives out there you can get about everywhere? Just curious. What will be a good starter pack to get , maybe something on E bay.... 1 ml will probably last me a lifetime.
Mark, I just joined this site and I am super excited about finding it. I left you a post on one of your you tube videos (Dave Matthews) about how great your videos are and how much I have learned from them. I'm retired and this is such a great hobby for me that takes up some time and keeps me out of trouble, at least until Happy Hour! Thanks Mark!
Thanks Matthd - stick around and be part of the community :)
There was one part that made me smile "It is good practice to clean oil pots and replenish with fresh oil every week"
The Author must be well off as Moebius Synt-a-lube 9010 for instance is at least a tenner for a couple of mil.
Vic
No wonder the vultures were circling around my roof all these days! :notfair:
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring it is still good. II am awaiting the replacement setting, and I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
