problem with seiko 7s26
i have a seiko 7s26 that i have used to make a rather nice pilot watch. i can't remember where the movement came from. it runs all day long while it is dial down. but, when i flip it over, such as would be worn on your wrist, it slows and stops almost immediately.
i have not taken this movement apart, but when i do, what should i look for?
guessing, but i'd say balance assembly or pallet/jewels incabloc, dirty, cracked, worn or bent pivot(s), too much endshake or not enough, seen this on pocket watches, takes a pretty hard knock to get Seikos out of whack, balance staffs and roller jewels are usually robust unless they are dirty. hope that helps
Look for wear in the train wheel bridge and movement plate? Where the arbor is. That is a place where Seiko is usually worn. To much movement and the barrel will lock when you have the movement in different positions?
well, i have narrowed it down by accident. i swapped the balance into an NH35 movement that i have also. the thing took off running immediately. it ran all night in the inverted position, but when i turned it over, it stopped.
so, it looks like the balance is dodgy. i'll pull it and look for a pivot to be damaged. this might be the solution.
