My Trio
I suppose it comes down to how often you'd use it if you can justify around £100 for the Bergeon compared to probably £30 max to make multiple ones.
The Barrel measures 21.75mm and the biggest Watch-Craft winder is 16.40mm The Winder is of a Swiss made watch so maybe Bergeon would be the only option, I know the did a Clock set that satrted at 21mm and that one just looked like a bigger version of their current winders.
By Embezelled · Posted
Thank you! Oh and too late to edit out some typos, but "will perhaps a Seiko Crown" was supposed to be "will perhaps get a Seiko Crown". And I realize now that A-O3 should be AO-3. -
Yes, good advice! Or dig through all my threads on the forum to read about misadventures with American pocket watches. You end up needing many additional vintage tools succeed with most old pocket watches. And if you have already worked on the ST36 a few times then you have already built the tweezer skills needed for wristwatch movements. Return to the railroad watches once you are accustomed to hunting for tools and parts.
