Jewel seat opening tool
szbalogh
I had a free half day yesterday and made this tool. Two ~10cm long 6mm diameter rods were grinded to its half size then shimmed together. The tip was turned in the ER20 "lathe".
Yes i had to push the workpiece deeper.  It was a real pain making it round initially. I also had to improve the lathe driving setup. A bigger wheel was needed on the electric motor to achieve higher speed.
The tip is 1.3mm in diameter. This just fits in the smallest hole i could find in my watches. This was not the final shape :)
The two half of the tool.
And the finished tool in open position. The screw has an M3 thread. A slot was cut in one half to avoid stress on the welding at the end.
Now comes the question how to use it properly? To set the desired diameter and turn, or ream one dierction then decrease the tool and ream in other direction? Is a video out there showing the process? I want to try it today night :)
Edited by szbalogh
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
