Strange behavior in rete
This is my chinese GMT Matster homage watch wearing it all day long now for 3-4 months. Inside is a DG2813 with nonadjustable 24h hand and date complications. Serviced myself, which does not men it is properly done :) Moreover, it has built-in autowinding mechanism which means i have to align 5 pinions properly at the same time. So, it was tricky putting it together. Also broke one of the icabloc springs which i replaced with a different shaped one.
The problem is that the watch is keeping excellent time for 3-4 weeks and then comes a big loss in the rate. Then i adjust the hairspring preload. This happened 3-4 times as i remember. Last week it made -2,5 s/d in average, deviation was ~15 s/d. Now today it fell down to -80 - -100 s/d. What can do such sudden jumps in the rate? Watch seems healthy.
7 minutes ago, clockboy said:
Its a strange one as the amplitude is good. When you fitted the shock spring did you check it is secure i.e. holding the cap jewel in all positions.
How can i check the cap jewel? It was ok as i remember.
But it seems that it is more stable now in the different positions.
You adjusted what? There is no preload in the airspring. If the rate changes that means the effective hairspring length has changed.
Ah sorry, not perfect in english, google suggested me "preload" :biggrin: I wanted to say "effective hairspring length".
The regulator is hard to move, i am sure it couldnt not move.
It must move, otherwise the rate can't be regulated. Also, if it has an etachron style pin, that is used for regulation and adjustment also.
Edited by jdm
4 minutes ago, jdm said:
It must move, otherwise the rate can't be adjusted. Also, if it has am etachron style pin, that is used for regulation and adjustment also.
No etachron pin, simple as possible movement. ?i=http%3A%2F%2Fwww.ofrei.com%2Fimages%2
Meanwhile made more measurements and now it has simply no deviation in rate in the different positions. Day before yesterday i had this report:
It seems that the jewel or the bridge was moved indeed. Maybe the balance was not touching the cap jewels with both ends.
Assembled the measuring system this week and now i see strange things :)
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
