Dremel lathe
szbalogh
Some of You asked about my Dremel "lathe". I will post my works here with this fine tool :)
To use the Dremel as a lathe please make sure that the bearings are in perfect condition! In addition, care must be taken no to push the tool to hard on the working piece, since the shaft is to long and thin. The tool can blunted ot the working piece can break or bend. Moreover, use only the low speed stage! The manual say it is around 15000 pm for my Dremel but I am sure its a way slower.
Here, i am turning a stem for an EB1197 movement:
This was my first documented try, see this video for a much better pice for HMT watch:
Today i got one crown for it so continued work on the EB1197 stem.
Thread was cut also on the Dremel holding (and pushing) the die with 3 fingers and turning the collet with my other hand:
The Dremel is just tied with wire to a piece of iron beam. Between them are two wood pieces (one at the front and one at the end of the Dremel) with a half-circle cut to fit the two support points. Notice my adjustable T-rest! :)
Here i had to make a longer thread and shorten the length:
Just a bit more to cut down:
Using a set of collets You can see in the upper left corner. They are coming from an 8 pieces set ranging from 1 to 3.2 mm as i remember. Just search for "Dremel collet" on e-bay!
You have to check the Dremel shaft diameter since there are more available.
Just fits in the 1.8mm collet, the thread is tap7 (120 or M1.2x0.25).
It is important to note that the delicate front part has to made in one run, since the work piece wont be true after removing and putting back in the collet. But to cut down the length it does not matter.
The length is perfect now, lets glue the crown and the stem together:
And of course it is working flawless :)
Ready to go:
Next time i will make a replacement dial feet holding screw for my Roskopf pocket watch.
Edited by szbalogh
Thank You Bobm12! Also will make a simple ER20 system lathe in the near future. With that i have much more possibilities. Like turning bigger parts for example crowns or staking set rods. I am half way to make a little "two center" lathe for pinion polishing. Stay tuned! ;)
Excellent SZ! Can I ask, what do you use and/or how do you make the tools to cut on the dremel lathe? I would assume they have to be of a certain shape and with quite and edge? Forgive my ignorance about lathes!
Cheers,
Bob
1 minute ago, bobm12 said:
Bob
The big square tool on in the video is a 3mm diameter HSS Co10 rod. Sadly i couldt find any square one. Hardness is around 70 HRC.
The small tool is a "Vinyl cutting Roland blade", These are tungsten carbide tips, excellent for hardened steel, but have to work slower with it since it breaks easy. Hardness is around 90 HRC.
http://www.ebay.com/itm/5-Pcs-30-45-60-Roland-Blades-Cricut-Cutting-Plotter-Vinyl-Cutter-Offset-Gcc-/331442278668?var=540617452215&_trksid=p2056016.m2516.l5255
The tip is not good for turning, it has to be shaped. I use this diamond disks for it:
http://www.ebay.com/itm/Hot-5-PCS-22mm-Emery-Diamond-cutting-blades-Drill-Bit-1-Mandrel-for-Dremel-NEW-/272150698231?&_trksid=p2056016.m2516.l5255
Using this collet for both tools, also excellent for screwhead polishing...
http://www.ebay.com/itm/DOUBLE-END-PIN-VISE-TONG-STEEL-WITH-2-REVERSIABLE-COLLETS-2450167-/272212383988?&_trksid=p2056016.m2516.l5255
Also have a 3mm diameter tungsten carbide rod, but didnt used yet. I will replace the HSS tool with it.
http://www.ebay.com/itm/3-12mm-K20-Tungsten-Carbide-100mm-Rod-Boring-Bar-Lathe-CNC-TOOL-MAKER-Endmill-AU-/121475845355?var=420413595861&_trksid=p2056016.m2516.l5255
Today i needed to make one dial feet holding screw for the Roskopf to try on the new domed glass a grinded. Started from a 3mm nail.
M1.2 thread since the previous screw (M0.9) was broken and had to push out. Roughly shaped upper part.
Nut cutting with my new "special file" :) an old broken pocket knife.
The new one on the right.
And finally i could put it all together after a bit dial feet adjustment.
    • A couple of pictures of the front… Sorry, I’m months away from this one, but…there is an edge to the bezel but I see no obvious signs of previous bezel removal and it is quite thick so it would be difficult to a grab an edge on the crystal with a crystal lift. It does look like in/out thru the back…good luck…
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
