Another "motor barrel" ?
A Hebdomas 8 Jours pocket watch is fitted with a very long mainspring in a big barrel.
The outside of the barrel turns when you winding the watch (60 full turns once a week).
You can see the click in the upper left.
EJ
I have come across this in types of old travel clocks but I can't remember the names. I found the springs to be very strong and not a very satisfactory way of winding, the spring would rip the barrel from the inside and this would cause the spring to slip more then it should, the other fault was with the click and the teeth because of the strong spring it would cause wear in the teeth and on the click, you would almost have it fully wound and at the last turn slip right back and nearly take your hand off. Never seen it in a pocket watch.
