Hi,
I've just started to fix and replace movements in watches and have a pretty extensive collection, I've noticed that the crown and wonder has disappeared from my Alpha, how do I replace it? I don't have any measurements or know what type I need, anyone know?
Also I've been practicing crown removals but have been unsuccessful with quartz movements, the YouTube tutorials were great for automatics but no quartz?? Any tips there?
Thanks!
Rob
Edited by RobMayer
spelling error
Hi Rob, could you post a picture of the problem area? -- and if possible of an original same model of the watch showing the crown?  When you don't have an original crown and are looking for one, it is beneficial to:
1/ find a picture of the model to get an idea what you will be looking for
2/ measure the place where the crown usually fits in to estimate the diameter and height of the replacement one before ordering...if a direct replacement is not available (by the model of the watch as this is a case part).
3/ Also, do you have the stem? Otherwise, you need to know the movement caliber to order one and fit it to the new crown. The thread is also an issue when ordering the crown (most important).
Cheers,
Bob
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
