Do I re-oil after taking a watch apart after service?
Thanks Rich and scott for that information, so much more to learn. -
Ah i didn't notice that but it was past one i the morning when read it -
That is what I have moved to, I said 9010 in my post for the sake of simplicity, but what I actually use is Dr Tillwich 1-3 where I would use 9010 and Dr Tillwich 3-5 where I would use HP1300/D5, similarly I use their B52 grease instead of the Mobius/Molycote ones. Only downside I see is that they are all clear, including the grease, so you need to be a little more careful on how much you apply as it's not so easy to see the oil/grease.
If it has a e on the end, Remontoire then yes two springs, without the e, stem wound. -
Thats more or less what i do, ive heard a few people recommend dr. Tillwich oil All those jewels and non to be had on the pallet ? Could have been one of those companies like oris that were restricted from using new design features like jewelled levers.
