Hi, my first ever forum post.
I repaired a tag watch belonging to my son. It involved a change of movement ( eta 955.112). Put it all back together and wore it a while to test, all ok. Gave it back to my son and it ran great for a while but now although it keeps perfect time it ticks once every 4 secs instead of every second.
Does anyone happen to know why?
