Hiya all, I've just acquired an early Tag Heuer F1 mid sized with stainless steel bracelet and it is in great condition apart from the white and red markers and numbers on the bezel are looking tired.
Just wondering if anyone has had any success repainting them as a replacement is too expensive considering I only gave £50 for the watch.
Thanks, Andy.
If they are lower then the bezel? You could fill the cavity with some humbrol modelpaint. Let it almost dry and wipe of the bezel. Have done that on some citizen bezels. With good result.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
