Is it possible to straighten this pivot?
Fully wound I presume ?   End shake adjust in escapement is significant, if excessive then fork pallets and escape teeth interface change in different positions, thus small misalignments let pallets face or escape teeth to extremes of free play interval, where escape teeth can't escape. So when adjusting end shakes, you want fork pallets and escape teeth in one plane with minimum end shakes.     Â
Is that a bloody big pencil or a very tiny part. I think, I knew the answer. -
Three of the broken teeth have now been located and removed. I haven’t counted the total number yet, but it would be a huge relief if I manage to find them all. The nightmare scenario is missing a tooth that survives cleaning and ends up jamming something important. The hunt continues! Oh, and that thing you see on the right in the last picture? Yep—that’s just the tip of my pencil! 😅
Interesting the dangers of IPA? But it brings up a problem Elma recommends IPA as the final rinse in situations where the normal rinse will not evaporates. I've never actually looked at the programming of the cleaning machine as to how long it actually spends in the IPA it shouldn't really be that long. When I was cleaning watches at home I was using alcohol that the container it came in specifically said it would dissolves shellac and still never had a problem because the final rinse of alcohol is only supposed to rinse off the previous rinse so here in their? To be honest I never really times when I was doing it I would just put the parts in a beaker dump in alcohol swish it around the rinse it off and then put it right in the dryer. The problem would be extended time and especially if you heat up your alcohol that would speed up bad consequences. The problem with this choice of a cleaning product is it isn't actually for cleaning watch movements. https://store.elma-ultrasonic.com/en/products/ec-90 If you look through the discussion group I know we've talked about alternative cleaning products and? The problem with alternative products is experimentation is required. Plus the commercial stuff really works nicely but? We now end up with an interesting problem and watch repair which is environmental air quality for human beings. If you look at the quote above there is an excellent suggestion a box with ventilation system. If you look at the very newest of cleaning machines that's basically what they do they pull air in the machine so nothing gets out and it goes through a hose either outside or through an activated carbon filter. Â Â Â
I don't trust myself with a hammer! It's funny though - I've got my dad machining up several little crystal press attachments when really I could just hammer it!Â
