Hi All.
I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project.
I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.
I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.
One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service.
The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?
For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills.
I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this?
Thank you.
Welcome to the WRT-Forum!
Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
Edited by Kalanag
Welcome to the forum.
You're best starting with something that you know runs well and keeps good time.
That way when you've stripped and service it, any problems are due to something you've done.
Thank you.
No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition?
I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on?
I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
Welcome to the WRT forum.
 Both pieces are worth TLC, they don't make them like these anymore, so you are looking at a limited available quantity. I suggest working on them when you have acquired good dexterity and experience.
 Chinese keep making same chunk= junk and  love to see you break them, so to sell you another one, the fact that  they don't sell spare parts supports the point of my arguement.
 If you are buying now, why not buy two Swiss scraps of the SAME CALIBER in need of repair, such that a good running one can be made out of the two, plus,  you will have your own spare parts inventory, well sorta.
Keep us posted when choosing scraps  and ask questions, no $  charge for advice.
 No shortage of help and advice here, we'll work with you till your rebuild one ticks happy and accurate.
Regs
1 hour ago, watchweasol said:
Hello welcome to the forum.   I have added a couple of documents you may find worth reading
TZIllustratedGlossary.pdf 4.2 MB · 1 download TM 9-1575.pdf 14.25 MB · 1 download
The War Department recommends Elgin M-56A oil.  Elgin later came out with M-56B which is better.  You will find the Elgin M-56B in cool "one-drop" bottles on ebay for under $20.  Get one and discipline yourself not to read any threads on "what oil should I buy."
Get a brand new set of Bergeon screwdrivers2025-05-0808_36_21-Window.thumb.jpg.c64a06374335083668ae22f2820fcbec.jpg
They are not that expensive.
Get a pair of Dumont #3 tweezers.  If you were a boy scout and no how to sharpen a knife, find a pair of Dumont #3 on ebay that is in reasonably good shape and buy them--they are better.  Then dress them with a stone using your boy-scout skills.
Once you become a skilled amateur, you will be confident to invest several thousand dollars in the 14 different Mobius oils that the experts recommend (SARC).
I would not practice on the Ingersoll for two reasons: 1) it is constructed a little different than your typical Swiss watch, and 2) (more importantly) it is a very cool watch!  Later on, I would fix it and wear it.
Thank you very much for the very helpful info, folks. A lot of reading to do!
I do like the look of that ingersoll.
I am in the UK, so I think moebius is more readily available than Elgin. I hear 8000 does the trick as a jack of all trades.
Given the rather sorry state of the Benrus, if I get the movement to run (If wound, it ticks for about 2-5 seconds then stops. Give it a tap, it ruins again, then stops again), What are the chances that I'll be able to fit it into an ST36 case (perhaps with a 3d-printed adapter)? I don't think I'll have the spare cash to invest in case re-plating and dial re-finishing!
I would really appreciate some info/links on how to clean the parts: is it achievable without a ultrasonic cleaner, or am I better off buying one and not wasting my time?
Also, can I get away with a timegrapher app on pc/phone?
Chances of fitting that movement into a modern case with pleasing results are not good unfortunately. Dial size, pinion height, the position of the stem relative to the thickness of the movement all play a role, so cases made for a specific movement are really only workable for that movement. If you have a lot of skill in 3D modeling you might find a way to make it work, but it would be a significant challenge.
A case made for an ST36 would be gigantic in relation to the Benrus movement. A case made for something like a Seiko NH35 would be closer to a workable diameter, but most of those modern cases are made for automatic movements that are much thicker than vintage hand wound movements.
Edited by mbwatch
Yes, however, as you are just starting out, you can progress using Ronsonol lighter fluid (or equiv) to clean.  Use pegwood to clean all pivot bearings.
Yes.  Some disagree with me.  I have many hundreds of dollars invested in multiple time graphers and vintage timing machines.  The phone app is just fine for a beginner.
Probably just needs a good cleaning.
My SWAG, is slim to none unless you own a 3D printer and can design and print a spacer
Here is a re-cased Mickey Mouse watch I made using 3D printer...lol!!
Thank you very much for being extremely helpful and patient.
I know a guy who can 3dprint, I can design a spacer I guess.
For cleaning with the lighter fluid, is it entirely done by hand, or do I need a jig (spinner?). Any informative links appreciated!
Would you have any suggestions for the app? I'll test it on my Slava.
I suggest FreeCAD as the tool to use for 3D design. It is free open source.
For Android phones, I use "Watch Accuracy Timer"
For cleaning, just get a class dish and soak the movement parts in fluid.  Dry on lint free paper under an incandescent lamp.
Once you decide to invest in the hobby, there are many ideas for DIY cleaning machines and chemicals.  I use traditional spin machines and the expensive L&R fluids.  I have invested $$$$$$ into this "hobby" but I have the means to do crazy stuff.
8 minutes ago, tomh207 said:
Have a look here, quite a good video about cleaning without a machine
I do exactly what he does for rinse.  I use the L&R Master designed for two rinse jars PLUS an extra rinse jar.  Great video
I'm in the " crack on with what you have " camp. Since you are in the Uk Ingersolls are plentiful, mostly the Great Britain models, but the Swiss made ones are still fairly common on Ebay. The New Chinese clones, were difficult to get parts for...🤔....I'm not sure if they still are, the quality wasn't that great either when it came to things like shock springs. Another complete watch same model Ingersoll will probably set you back less that a couple of clone parts that you will almost certainly lose or break. I never took apart a new working movement, I don't believe it held back my learning at all, in fact quite the opposite.
    • I'm in the " crack on with what you have " camp. Since you are in the Uk Ingersolls are plentiful, mostly the Great Britain models, but the Swiss made ones are still fairly common on Ebay. The New Chinese clones, were difficult to get parts for...🤔....I'm not sure if they still are, the quality wasn't that great either when it came to things like shock springs. Another complete watch same model Ingersoll will probably set you back less that a couple of clone parts that you will almost certainly lose or break. I never took apart a new working movement, I don't believe it held back my learning at all, in fact quite the opposite.
    • Yeah I can't take credit there - I thought the plastic punch thing was a work of genius when I first discovered it!
    • Since I've learned lots here I thought I'd share a tip I picked up elsewhere and put to the test... For that 6105/6309 bezel lume pip look I've punched a clear plastic bottle of water, sanded it for the frost effect, removed the (smaller) pip from a standard/cheap replacement bezel, drilled it out to 2.5mm and fitted it using a smaller punch - fresh lume to hold into place.  Pressing into place is a bit awkward but you soon get the hang of it, and the end result is pretty decent I'd say... The worst part probably being the drilling rather than the pip!      It started out like this:
    • Ive asked this at a Seiko forum but I know there's plenty of experience here too...   As I have it the recently discovered servicing technique on these is that you stuff the crown full of gaskets and work it until the recessed washer pops, remove the washer, switch the gasket out, dish the washer and push it back into place, levelling out the washer in the process? First attempt did not go to plan... I tried using a plastic pusher to manipulate the gaskets in the crown... Wasn't strong enough and I was struggling to even get the gaskets in up until it broke.   Rethink consists of making/using actual tools: I don't have a staking set, so I've got the old man fashioning a metal pusher, essentially a 2.45mm OD tube with 1.6mm ID with a 6mm press the other end. Also got him on a dishing block/conical stake (sorry I'm terrible with terms) and a holder for the crown while I'm working on it...   I figure that's enough to do the process described above? Push with the metal pusher, dish the washer with the conical stake, press back in with wider flat press (drilled centre so it doesn't catch on the tap).    Plan is to stuff, press by hand and repeat? If that doesn't work by hand I've a drill press I could attach the pusher to for a little more leverage if needed. (Obviously I don't want to go too mad with that, and hopefully can avoid it altogether...)   Sounds like a plan? I'd welcome any advice here, since I really don't want to wreck a crown. Having replaced all the other seals though id really like to sort these too. I welcome any input/advice from those who have been there and done it... Thanks!
