Hi, this is the first place I found when looking for advice so I hope someone could advise me.
Im completely new to touching watches but I’ve always wondered how they work.
I’ve bought a cheap movement, an ETA replica to take apart and rebuild.
Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop?
My goal is just to have a go first and see if I enjoy it enough before buying more tools.
Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?
With quality tools being relatively expensive I’m unsure what to buy.
Any advice would be greatly appreciated!
Edited by Sutcliffe
52 minutes ago, watchweasol said:
Hello and welcome to the forum, the best path to take is to get some medium priced tools , look at Cousins UK . They are a material house and are open to all. There medium priced screwdrivers are middle of the road and wil if looked fore serve you well into the foture I have added a little reading for you to help.
TZIllustratedGlossary.pdf 4.2 MB · 1 download Watch_tools_tipps.pdf 33.12 kB · 1 download
Thanks for your reply it’s greatly appreciated! I’ll take a look at cousins and get a list put together. I had a feeling that the cheap kits online would be a waste of my time.
Would you say my short list of tools is adequate for working on a movement only? Also, I’m unsure of the tool sizing as there are loads of options available.
Im just practicing at this point so there’s no case/dial, I’m interested in the movement first.
Also thank you for the reading material 😄
Edited by Sutcliffe
I agree with the screwdrivers, you can buy bergeon replacement blades pretty cheaply, I wouldn't scrimp on tweezers though, good tweezers make a huge difference.  Dumont are recommend, No 5 for general work.
Thanks RichardHarris 🙏
So a half decent, mid range screwdriver set, I can then replace the blades with Bergeon blades if need be. What are the most common sizes to start off with?
And a set of Dumont No5 tweezers to start me off. Assuming I’ll get different sizes and tip materials when/if I start to work on better quality movements.
These are perfectly acceptable to begin with.
https://www.cousinsuk.com/product/value-screwdriver-sets-rotating-stands
Have a look under, resources, day one tools on here.
Oil/ grease wise, don't tell anyone but I started of with genetic watch oil/grease.  My reasoning was, can I disassemble, clean, reassemble and the movement still runs. Once I could do that, I bought the correct lubricants.
I’m sure these will be good enough for me to take my movement apart a few times.
Regards to oil, I’ve heard the specific movement I’ve bought often comes dry which obviously can be an issue although they still run.. I may also just use a basic oil as I highly doubt I will be using the movement for anything other than practice. Thats assuming I don’t break half of it on my first try 😂
