Hi folks,
I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability.
I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil).
So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money.
I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so?
Thanks!
As the question is about indexing, see this video.
The quality is bad, but You can see how my setup for wheel cutting works and how the indexing is done. The index disk is just printed on paper.
Otherwise, as it is seen, I use minilathe for the purpose of watchmaking and I find it more convinient than regular watchmakers lathe
Edited by nevenbekriev
My suggestion would be as you are in USA to take a look at Sherline because they are in USA & still in business & you can not only buy the lathe but also a milling attachment & a manual or computer controlled indexer either separately or as a complete kit.
I don’t have Sherline or have anything to do with Sherline but a lot of people doing watch & or clocks use them to do some very nice work , have a look at Jerry Kieffer on NAWCC.
https://www.google.com/search?q=mb.nawcc.org+Jerry+Kieffer&rlz=1C9BKJA_enGB1138GB1138&oq=mb.nawcc.org+Jerry+Kieffer&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigAdIBCTI4NjI2ajBqN6gCE7ACAeIDBBgBIF_xBf8MHBWZkt3l&hl=en-GB&sourceid=chrome-mobile&ie=UTF-8
Dell
Often times the belief is when you're making small parts you Need a small lathe like a watchmaker's lathe to make small parts. But for gear cutting its oftentimes better to have something bigger. Then realistically you might end up with several things not just one machine for everything.
Depends upon your machining skills and the equipment you have. This is where having a slightly bigger equipment allows you to make all kinds of things where if you have a tiny equipment you can not really make bigger stuff it's very awkward. Then indexing is all kinds of ways to do indexing a very popular way is with the stepping motor a worm gear like at the link below
https://www.ebay.com/itm/191714031261
What's interesting with something like this is you can micro step at end up with basically a infinite quantity of indexing. But you still have to build some things.
For instance here's an interesting YouTube channel and an interesting video. His watchmaker's lathe is a little bigger than what I'm typically used to for watchmakers lathe. As a rather interesting cross slide and notice he makes just about everything. Then he gets the indexing something purchased surplus but it's basically just a worm gear stepping motor his has way more hands-on control but it does the exact same thing as the one up above. Then if you read the description of the video is in a shop of creative people to build all kinds of nifty things like the stepper motor controller etc.
I own too many WW lathes, as well as two sherline lathes and a sherline mill with a cnc indexing rotary table. The majority of my experience is using the WW lathes to make staffs, screws, and stems.
Recently, I have been experimenting making a pinion on the mill using the indexing table. It works. So, if you want to cut wheels, get the Sherline mill and indexing table...imho
Thank you all for the tips and insights. I'm looking carefully at the Sherline lathes with a milling attachment. I need to figure out exactly what I'd need to get in terms of the base lathe and attachments to be able to fabricate basic parts and learn how to fabricate some of the less basic ones- like a cannon pinion.
Thank you again.
Indeed. I would not attempt one.
Here is my messy Sherline setup
NIce!
Unfortunately, I may have a movement or two for which a cannon pinion simply does not exist. I figure it's a challenge- put the movements on the shelf, work on other watches for a while, but also learn how to fabricate parts, and once I'm good enough at it, revisit the watch.
The worst possible result is failure, and that doesn't bug me much. 🙂
19 minutes ago, coreymsnow said:
NIce!
I appreciate your unbridled enthusiasm. We're you born in Texas?
I set an ebay watch on impossible parts...eventually they show up.
Heh. Well, also I just want to be able to do it, for no other reason than it's interesting. Same reason I restore antique tube radios and ancient computers- like, from the 1970s.
Sometimes, the parts just aren't there and you have to know how to make them. Learning how is a challenge and can take months or years, but it's honestly the best part! You can't beat that sense of triumph when you do something that's really hard to learn to do and do it well.
You shoulda been born in Texas.
Tough to make a vacuum tube though. You can substitute with a MOSFET eq ckt I guess.
I was playing around making a pinion the other day. More to it than meets the eye.
Hah! Well, California will have to do. Lived in TX for a brief period back in the early 70s, though, so maybe that counts. 🙂
Funny you should mention making vacuum tubes- I've actually tinkered with that! It's REALLY tough to do, and I've never made one more complicated than a simple diode that barely worked, but I have played around at it. But there's just no infrastructure for vacuum tube fabrication. I can get a lathe and learn how to use it to make complex parts, and while it might take a while to learn- and money to get the equipment, of course- it is possible to do more or less "off the shelf". But vacuum tubes, not so much. There are a few folks out there doing some crazy cool work with bespoke tubes, but they have setups that are far beyond what I can manage in my environment and it's mostly stuff they built by hand.
I also have been playing with making piezoelectric Rochelle Salt crystals to replace ancient vacuum tube turntable needles- nobody's made those commercially for probably 60 years.
I'm a sucker for learning how to do weird things no one does any more so I can make things no one uses work again.
(I think this is drifting off the topic of lathes, lol).
Back to lathes...I think you need the sherline mill and a ww lathe. I bought my sherline lathe simply to hold larger work pieces than a WW lathe. So far I have usedbit for making tools and not watch or clock parts. Done very little with the mill, but did experiment with making opinions. Lile yourself, I am a novice that does not shrink from trying the impossible...up to a point.
There is a guy on NAWCC forum, Jerry Kieffer who is the master of the Sherline for horologi al work.
I have a WW lathe, a taig lathe, and a sherline mill. I just finished building my rotary table indexer. If you have some programming/electrical knowledge, they can be built very cheap. I have roughly $150 into my build.
Edited by SwissSeiko
Pics
I do indeed have some programming and electronics know-how. 3 decades writing code for a living, and playing with microcontrollers as a hobby. 🙂 It helps with my actual living of being a voice actor because I can maintain my own equipment- no one around to replace the caps or the tube in an obscure botique mic that isn't made or supported any longer. Also saves money maintaining and cleaning my own interfaces and mixers when they develop problems in the faders and such.
That said...
I do have a question that, I'm sure, will betray my ignorance about certain areas that I have yet to fill in. I understand a "WW" lathe is a "Webster Whitcomb", but from what I understand that is a style of lathe and not a brand, correct? If someone would be willing to clarify and maybe expand on the terminology, it would be helpful so I can better understand the advice being given and know what I need to look into to further my knowledge.
For example, a Sherline mill would appear to be either a separate piece of gear or an attachment/expansion to their smaller lathe. When you say you have a WW lathe and a sherline mill, can you say exactly what devices you have?
Thank you!
(I just realized I have a few Raspberry Pis and some Arduinos of various form factors around here I could probably put to good use in a scenario like you describe above).
Edited by coreymsnow
addl info.
It was first a brand, but became a standardized style. So you will find some older lathes actually marked "Webster Whitcomb" and many other makers who built WW lathes conforming to the same dimensions for spindle height, bed shape, attachment setup, collet size and design. https://www.lathes.co.uk/derbyshire/
So when someone mentions a WW lathe today, they are talking about any lathe that conforms to the standard, which could be a 110 year old American made lathe or a European made lathe from the 1960s or something else.
Edited by mbwatch
Excellent info, thank you! So when you say "conforms to the standard" does that mean, for example, that parts are interchangeable between brands and ages, or that you could use accessories built for that 110-year old one on a newer one that was built in the 1990s?
Also, thank you for taking the time to answer my questions and your patience.
If only things were so easy...😀.
Both lathes in this picture are WW-style lathes.. nuff said? 😉
Got it. So a WW lathe will have that graduated drive pulley for different speeds and similar setup for the bed and tailstock, but they won't be fully compatible with one another in terms of parts.
Thanks! The picture helps a lot.
On a watch repair discussion group that you know that we love to see naked watches out of the case you show us a box?
I think a book on watchmakers lathes should be helpful.
 The watchmakers' lathe, its use and abuse; a story of the lathe in its various forms, past and present, its construction and proper uses
by     Goodrich, Ward L
https://archive.org/details/watchmakerslathe00good
You also have another potential issue with head and tail stocks, in my research it would seem that for the American style lathes the head and tail stocks were bored as a pair. So a matched pair is good a “pair “ made up from two different lathes cause some headaches. The Swiss Geneva style lathes are much lighter but were apparently made to fit any lathe. I have seen mention of being able to shim the tailstock as well to true up.
indexing is again not so straightforward for a watchmaker lathe, at least not as I have found so far. Often a lathe will come with basic indexing which is limited to 60 positions. The full index plates do come up at times for eywatering prices. It is very possible to do that electronically. As well as what @SwissSeiko maybe able to point you to have a look here.
https://imakewatches.com/projects/CNCIndexDriver.html
https://imakewatches.com/projects/MillingAttachment.html
Tom
Some of the older American companies did at least claim to manufacture them so reliably that any one of their tailstocks should perfectly center any one of their headstocks. But it would take probably someone like nickelsilver to verify that in a big enough collection.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
