Wooden Watches!
Once in a while something comes along that just blows my mind, and this certainly is one.
post-124-0-86444300-1449696130_thumb.jpe
I have studied hundreds of watch movements and as an engineer have been in complete awe of many, but these wooden creations are right up there as far as complexity and skill of manufacture is concerned.
More information can be found here:-
http://twistedsifter.com/2013/07/wooden-watches-by-valerii-danevych/
Is it carved or molded out of compressed wood? It looks like what a Klingon would wear as a watch. Very cool and, if it was featured in a Sci-Fi movie, it would be as an "antique"! Oh, whatever, old man's rambling here....I love the watch!
Cheers,
Bob
PS. Just visited the site. Not pressed wood but real one, and Danevych makes all sort of watches and clocks amazing looks and detail! Impressive this type of workmanship and skill.
i love it! i wonder what the change in humidity would do to it, tho. this kind of craftsmanship is just about unparalleled anywhere.
a bit OT, i was watching a NOVA program about finding latitude. one of the clockmakers featured - actually the person that the story revolved around - made a wooden clock back in the 1700's.  it still runs today somewhere in the UK in, i believe, a church. it's wound every eight days and keeps accurate time. imagine 200 or so year old wood that is still going.
i wonder what these wooden watches sound like.
Edited by ramrod
Here you go:- http://www.gettyimages.com.au/detail/photo/brocklesbury-park-stables-and-clock-this-high-res-stock-photography/126604634
    • Thanks Ross, yes i remember the broken arbor screw you had to deal with. Dont give up, if i can drill a tiny hole in a bloody hard barrel arbor without breaking the drill bit then you'll get that screw out one day somehow .
    • Isn't it most correct to say that the mixture of radium decay pathway compounds found in old lume will produce both alpha and beta particle radiation as well as gamma rays, so it's over-simplistic to dismiss it all as low-energy particle emission? True, a cheap geiger counter chirping away with a raw CPM count won't specifically give you the relevant biological dose, but it makes it easy to tell the difference between your local background, a watch with a bit of activity, and one that is comparatively quite active. Each person can make their own risk analysis based on their understanding and concern, but there's nothing wrong with using an inexpensive meter to help make the determination.
    • A lesson I learned last month on a Junghans pocket watch where both pins were bent over like stalks of wheat in the wind. I bent them back straight, wondering what a shock the thing must have taken to somehow bend even the outside pin over. And then the escapement wouldn't unlock at all. Probably the pallet stones are too long but I'm not ready for that repair yet so I bent the pins back over and it runs 0/0.2
    • Never. Brilliant work and photographs. Thank you. On my very first watch I knackered the arbour. I think the screw I put in was the crown screw. I didn't know about left handed screws then. Head sheared off. Thread broken just below surface. If I had the space, then a lathe would be my wished purchase. 2 1/2 years later and I still get the arbour out now and again and...... I can dream. It's a lovely pocket watch. Ah well.
    • Hello Davis. This thread is interesting. Thought I'd add my twopenneth worth. A short while ago I had a similar problem to you. Not a broken banking pin, but I did alter a banking pin. Much to the consternation of members. Rightly so. However I did as they suggested and obtained a complete donor movement and installed it into the watch. The client, who I did not charge but did the work as a project for myself, was as happy as Larry.  Can you not look for watch of the same name? A Donor watch or movement.  Keep us posted on your result please.
