When turning staffs, a JKA is invaluable and expensive. Fortunately, I inherited mine. There are crude alternatives to a lathe...like chucking something up in a Makita drill motor and using various grit sandpaper to make a pin. Won't turn a staff that way!! But, you can make a pin.
10 hours ago, docrpm said:
This is probably one of those circumstances where I could use a lathe to reduce the diameter of the pin, right
 I don't use a lathe to reduce the diameter of the pin I use something else but I'm a bit puzzled as to why is it too big in this particular case is that's extremely big? By some chances as the balance bridge off another watch?
@JohnR725 The balance bridge is from the donor. I don’t think it’s bigger…It’s probably the same diameter but the center is displaced relative to the center of the hole in the baseplate. Not by much, obviously. What I was thinking of doing was just “shaving” off the smallest amount possible from the side of the pin where I think it’s creating friction. But @nevenbekriev wanted me to wait, so… 🙂
He's trying to tell you something like this isn't really a good plan.
Just a reminder of something when they quote something from the other page when I looked up your serial numbers
Estimated Production Year:    1937
Run Quantity:    4,000
Grade/Model Run:    310 of 329
Estimated Production Year:    1917
Run Quantity:    2,000
Grade/Model Run:    127 of 329
You will note that one of your watches was a batch of 2000 made in 1917 and the other was a batch of 4000 made in 1937.
Then did you notice how the main plate has a serial number the complete serial number? Then all the rest of the bridges have a partial of that serial number and typically the serial number is also scribed on the balance wheel. The problem with manufacturing when these watches were made was that there were variations as you can see the balance bridges do not interchange because they're not of the same batch.
Basically what happens is the main plate is made the bridges are made there assembled together and then the holes for the wheels the jewels etc. are done when everything is assembled as this is the only way they have to get all of the alignments absolutely perfect. Then each of the escapement's and balance wheels are adjusted for each watch.
Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright.
You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
Yep…This makes perfect sense. With that large a gap in the serial numbers, they were almost certainly machined on different equipment, hence one should have no expectation of any cross-batch compatibility. I’ll revert to the original bridge.
Regarding bending the bridge @nevenbekriev, I’ll give it a try, but I may have to buy some better calipers. My Vernier calipers are only accurate to 0.1mm. Not very accurate.
    • Are you certain the screw was not plated with nickel in the first place? Polishing the head may remove the plating and expose the steel to oxidizing while the rest of the screw is protected from oxidation. I have made this mistake... An unplated unpolished screw will turn blue but not look very nice. I agree about the container. It is much too big and acting as a heat sink. To get decent results I kept reducing my pan until I settled on a 3cm steel cup.
    • I've found a few similar with this first one being the most similar. I think the second one answers your question about the stem tube. https://empress.cc/products/1920s-rueff-freres-lugrin-minute-repeater-18k-gold-swiss-pocket-watch
    • The make do stem has a turned round shaft at the bottom, a little higher is the square but slightly tapered shaft, this fits in to the setting mechanism but only friction tight. The stem isn’t long enough to go right through the case so can only test and wind out of the case. In normal position the stem winds and if you push the hand setting lever (at 4 position) this separates the setting mechanism and the hands can be set, pushing the same lever back disengages it and it goes back in to the normal position. im unsure how the stem in this movement is prevented from dropping out, there are no threads in the crown shaft for a screwed sleeve.
    • Yep…This makes perfect sense. With that large a gap in the serial numbers, they were almost certainly machined on different equipment, hence one should have no expectation of any cross-batch compatibility. I’ll revert to the original bridge. Regarding bending the bridge @nevenbekriev, I’ll give it a try, but I may have to buy some better calipers. My Vernier calipers are only accurate to 0.1mm. Not very accurate.
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
