Hi there.
Watchmaking is packed with specialized tools, each designed for a single task. Unfortunately, when it comes to fitting a watch crystal, hands, and back case, these tasks each require tools with distinct designs, so a single tool that effectively handles all three doesn't really exist. However, after doing some research it seems there are some versatile tools and workarounds that can minimize your toolkit:
1. Crystal Press
  • A crystal press, with a set of interchangeable dies, can sometimes be adapted to press watch hands or close snap-on case backs.
  • While not ideal for hands (precision alignment is crucial), it works well for crystals and case backs if you have the right dies for the job
2. Hand-Setting Tool with Adaptations
  • Hand-setting tools are small and precise, usually limited to fitting watch hands. However, some advanced models might have replaceable tips that allow for more flexibility.
3. Case Press with Adjustable Dies - This is likely the best bet for versatility. With the correct dies, a case press can:
  • Fit watch crystals.
  • Close snap-on back cases.
  • (Potentially) press hands with very careful setup.
I am more interested in point no. 3, and therefore I am looking for recommendations and potentially pros and cons of using a case press with interchangeable dies. I am also not that interested in the extremely expensive brands, but rather something within the mid range.
Thank you.
Edited by dancad
A press to double up duty as caseback and crystal press is the norm, there is an order of magnitude difference between these functions and hand setting however. A multiple use tool that can be used for hands, jewel setting and cannon pinion adjustment would be the clone of the Horia jewelling tool.
using a crystal press to set hands is literally a sledgehammer to crack a nut
Tom
Expand
Hi Tom. Thanks for your reply.
The cystal/case back press seems a bit too chunky for hands indeed, however I was thinking that maybe due to the wheel handle on a Robur press, for example, that I've seen online, you can perhaps easily control the amount of pressure you apply when attaching the hands.
Is Robur a brand that you can recommend for at least those two tasks ?
Dan
Never been a lover of the hand fitting presses and always do them by hand.
Again never been into any fancy crystal or back tool so use these.
Expand
Based on this experience then no.
Expand
For now I am still using the hand fitting tool set which I bought from Amazon just to get me started, but it doesn't seem so precise and I already managed to bend a few hands. Either because of lack of experience or poor quality of those tools, or both. I've watched this guy on (Wristwatch Revival) youtube making those great watch restoration videos and in one of his videos I've seen this beautiful press is using for fitting the hands...seems so satisfying and very precise...
Edited by dancad
Tom
Expand
Absolutely Tom
Expand
I just fainted.
It's ok Im starting to come round and the missus has a strong cuppa on the way for me. It must have been bad because I'm missing words out, just give me a few minutes to compose myself.
Edited by Neverenoughwatches
  On 1/28/2025 at 9:28 AM, Neverenoughwatches said:
I just fainted.
It's ok Im starting to come round and the missus has a strong cuppa on the way for.
Expand
Blimey, you had me worried for a second there! Glad you're back among the living—sounds like the missus and a strong cuppa have life-saving powers. Don't forget to thank her for her heroic brew!
Thanks for stepping by.
  On 1/28/2025 at 9:10 AM, dancad said:
Expand
This looks a bit risky, by the way. The press pusher extends over the round base of the hand and presses on the actual hand (on the left). Like this, you are more likely to bend the hand. Marshall should better have chosen a slightly smaller pusher.
as others have said, definitely can't use a case press for hands.
Ok I'm back to normal..just...I dont know what happened there..some sort of shock to my system. 🤔 placing hands...nothing too spectacular...for me just tweezers to position the hands and a modified pointy stick to push them on. Look at the alignments through 12 hours of adjustment, adjust it if needed, pick up the movement....check the clearances between them the dial, indices, lume dots, whatever might be in the way through a full 12 hours of hand adjustment. Check them for parallel for cystal clearance...check that they are not loose...tighten if necessary...I think thats about it.
Expand
Even with experience, mistakes can still happen— I guess it's all part of the learning process. That's why I'm here: to gain knowledge and minimize those mistakes as much as possible. When it comes to fitting watch hands, do you prefer using a dedicated hand-setting tool or a press for the job?
Dan.
Expand
Glad you saw the funny side of it 😉
Expand
Oh, absolutely. I remember years ago visiting a watchmaker’s shop to get my watch serviced—what an experience! That dry, sarcastic sense of humor seems to be a hallmark of the trade. Honestly, watchmakers are a very special breed—kind of like the IT crowd but with fewer keyboards and more tiny screws.
Dan.
Expand
I used the simple, hand-held hand setting tools (that @AndyGSi showed) for the longest time. It worked just fine.
Only recently, I managed to pick up a vintage, dedicated hands press for 50 bucks and I love using it. But it's definitely one of the last tools you really need.
Expand
I definitely have a screw loose somewhere....if only I could find it.  You're a good sport Dan...you took it on the chin and volleyed one back...good man...I'm impressed 🙂
Expand
I must be destined for this then, soldier, IT now watch fiddling 🤪😂
I have a cheap hand setting press, used it once and now it sits at the back of a shelf collecting dust. I exclusively use the hand tools though if I ever get around to chronographs I would be tempted to make some delrin/acetal pushers for my Horia clone.
Tom
Expand
Haha, well, if you’ve got a screw loose, you’re already halfway to becoming a watchmaker—now you just need a loupe and a steady hand! And thanks, I try to keep up—it’s all about the banter, isn’t it? Keep ‘em coming, you’ve got a sharp wit yourself! Let's increase those numbers !
Expand
Yes, I've looked around for the longest time to find a way to use my staking set or Seitz tools. But I don't have a lathe nor 3D printer. So didn't find a good way to do that.
By the way, @tomh207, if you want to spend a lot of money 😅, Horia sells hand fitting pushers for their tool (I'd assume that they'd fit the clone, too??)
the set: https://www.horia.ch/en/Products/Jewellling-Setting-staking-tools/Set-of-pushers-and-anvils/Set-of-pushers-for-hands.html
individual pushers: https://www.horia.ch/en/Products/Jewellling-Setting-staking-tools/Pumppushersandanvils/Pushers-and-anvils-for-hands/Pusher-in-steel-and-delrin-only-N-1-N-11.html
Dan.
Expand
Sooo anyway after that short banter...personally I can't use any sort of hand press...i tried but visually it just doesn't work for. I would use it and want to pick it up and look at the movement from all angles to make sure I was happy. After a short while I excluded the press and just learnt to do it free hand. Once they are on and reasonably secure...pick up the movement..in its holder or case ...whatever the case may be , inspect and adjust at the same time with a pointy stick ( not a euphemism ) probe with a hole 🤷‍♂️
Expand
I will definitely stick to the hand tool set for now but I need to find a better set. The ones I bought for around 8 euros from Amazon are really bad quality, especially after I checked them under the loupe.
Should I go for better brands like Horotec or Bergeon for these tools ?
While looking for hands press I came across this one from eBay at 30euro...looks solid.
Edited by dancad
Expand
I don't think it's worth it. You can never hold you hand perfectly perpendicular (hence the need to check+adjust as @Neverenoughwatches explains). So there's no need to have a tool that is perfect.
If you forget about the look under the loupe, do your hand-held tools work in practice (after checking, adjusting, checking, adjusting)?
The check ones on Cousins have worked well enough for me. But I'm sure they won't look too perfect under the loupe/microscope, either.
Expand
These look like metal tips which is not what you want to be using.
Expand
Its always best to go for good quality if you can afford it, which in this case probably won't be too much for bergeon or horotec. Honestly I dont even have that, might be nice to ...but mine is literally a pointy stick with different plastic tips...those i use for adjustment, to press hands on I use a taped up flat steel bar with a hole in it...that I use on its flat..this has really good control over applied  pressure compared to an upright stick.
@Knebo I do know of the Horia ones lovingly crafted by vestal virgins and QA’d by angels from unicorn horns. That’s what made me think of making them from delrin or maybe nylon.
I think Rich @Neverenoughwatches touched on something unintentionally, unless you are using a height adjustable desk or a proper watchmaker bench it is a struggle to see properly, hold the press, place the hands and operate the press all at once. The usual watchmaker conundrum of needing 3 hands for the job.
Tom
Expand
Pretty much my thoughts Knebo...you get used to what you use...whatever they are.  But as Andy points out metal on a finished surface 🤔 not so great idea.
Expand
There’s something to what you’re saying. When I’ve spoken to professional watchmakers over the phone (which I stopped doing a long time ago) to seek advice or inquire about spare parts, I’ve definitely gotten the feeling that they’re thinking, “Another idiot who thinks servicing watches is as easy as servicing cars.” Eventually, it becomes an “occupational hazard.”
That, in turn, reminds me of a female student I had a few years ago who was above-average attractive. Every time I came near her to show or explain something, she reacted as if I were a drunk, obnoxious man trying to hit on her. And trust me, as a teacher, if you’re not professional and on top of your game in the private education sector I work in, you’re out of the game in no time. At a later point, I discussed this student with my boss and explained that her attitude could become a problem in a future workplace. I said she reacts as if she were working as a bartender in a nightclub, surrounded by a bunch of drunk, horny guys trying to get her into bed. My boss raised an eyebrow, looked down at her CV, and noted that she had primarily worked as a bartender! Speaking of occupational hazards!
  • Haha 3
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
    • What browser are you using Rich? Fine for me using Chrome
